Go to Post We want people to exercise Gracious Professionalism® and play at their best, but also not really because we find this archaic rule to satisfy something related to inspiring students to pursue careers in science and technology.™ - PayneTrain [more]
Unread 30-01-2012, 16:32
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Re: How to wire a SMC Solenoid Valve SY5220-5DO-C6 ?
Originally Posted by Alan Anderson View Post
Which style of connector are you using? Typically, the black wire goes to "ground" and the red wire goes to the pin you're using to control the solenoid. For a 24 volt solenoid, you will be using the Solenoid Breakout board on the NI 9472 digital sourcing module in slot 3 of the cRIO. Follow the Robot Power Distribution Diagram (24V Solenoid).
I am making my own wires.There are no wires coming out from the solenoid valve so I need to decide which pin should be wired to the red wire that goes to the breakout and which should be wired to the black.
Except of that , I know that it should be wired to the solenoid breakout.
