Go to Post Its a good bug too. :) - spadercool [more]
Unread 30-01-2012, 20:37
Andrew Lawrence
Posts: n/a
Why go over the bump
In response to this thread, I see a lot of teams who say it's best to go over the bump, but not why it isn't, or why it's advantageous to go over the bridge.
So the topic here is: What are the advantages of the bridge vs. the bump? What are the advantages that the bump has that the bridge doesn't, and vice versa?
Unread 30-01-2012, 20:49
Zembas's Avatar
Zembas Zembas is offline
AKA: Jonathan Oishi
FRC #0359 (The Hawaiian Kids)
Zembas is on a distinguished road
Re: Why go over the bump
I think that with the right setup, you can traverse the bump a lot faster than the bridge.
Unread 30-01-2012, 20:52
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Why handicap your robot?
Ben_Farmer's Avatar
Ben_Farmer Ben_Farmer is offline
FIRST Robotics Team 2945
AKA: Gilgion
FRC #2945 (Steel-Stangs)
Ben_Farmer is an unknown quantity at this point
I personally think, contrary to majority belief, that being able to lower and use the bridge is a much higher priority because just being able to lower the bridge, can enable a team to gain a vast amount of points at the end of the round. Additionally, the bump may prove harmful to any unprotected electronics/mechanics underneath the robot. Plus, there is always the possibility that the robot my become stranded balanced on top of the bump (unless it is designed to not do so).
Hope this helps.
Unread 30-01-2012, 20:56
Andrew Lawrence
Posts: n/a
We looked at the game and our strategies and thought "Honestly, how many times will we cross that middle section throughout the match". Our answer: 2, maybe 3 times maximum. We can use the extra time/weight elsewhere, most likely improving our bridge manipulator. Not only will we be better on the bridge, but we will be able to play our strategies much better than if we stuck to the bump.
Unread 30-01-2012, 21:16
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Your autonomous mode should do two things - make two 6-point baskets and go tip one or both of the allowed bridges to get the balls from it(them) onto your side. In fact, a good argument can be made for tipping the middle bridge your way should be your first priority, then return to the key edge (detecting that little bump) to make your free-throws. I see no advantage at all to kinect control. It is merely cape-waving FIRST-style. Perhaps I'll be surprised at Suffield Shakedown. I still can't guess how.
So dealing with the bridge is more important than crossing that barrier.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 30-01-2012, 21:19
Andrew Lawrence
Posts: n/a
We've found a few good ones, though I won't share them, think along the lines of this: You don't control how your robot does things, but maybe in a different way. Good luck!
Unread 30-01-2012, 21:30
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Honestly, I don't think building your robot to traverse the bump is worth the effort. How many times do you really need to cross it?
Prototype, Prototype, Prototype
Unread 30-01-2012, 21:31
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
The idea of going over the barrier appears to me as the choice of keeping the robot unpredictable to remain effective in the challenge. If a team is too limited, then other teams through scouting will notice and counter. Two bridges, one of them on the side requiring time to cross, seems quite limiting especially in the elimination matches with higher level play.
Unread 30-01-2012, 22:31
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Our robot's bridge device is the same device for climbing over the barrier, but climbing over the barrier will probably be our prefered method because it allows us to cross the field wherever and whenever we want to.
There are a variety of match scenerios that would show crossing the barrier is valuable. There are a variety of playing styles or strategies where crossing the barrier would be valuable... particularly on defense.
In our minds it wasn't an ability that required alot of time, energy or resources, esspecially when we combined it with our bridge tilting ability, so we wanted to have it. Time will tell how valuable it really is in a match... but my guess would be if more than 1/2 the robots on the field couldn't cross the barrier it could be really problematic and slow the pace of scoring and the match in general.
Unread 30-01-2012, 22:59
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
It is nearly always advantageous to be able to go anywhere on the field quickly.
The bridges do not allow this by design. IMHO most of the "good" teams this year will be able cross the barrier with minimal effort on their part. However, these teams will also be able to manipulate the bridge in order to balance for the end game bonus. If you had to choose one, the bridge is the better choice as it allows you to attempt the end game without alliance assistance.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 31-01-2012, 09:49
JABot67 JABot67 is offline
Unregistered User
AKA: John Bottenberg
FRC #2930 (Sonic Squirrels)
JABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond repute
I really can't think of an amazing reason that all good teams must be able to traverse the bump, but it does depend a whole lot on strategy. In 2010, the last game with zones separated by barriers, 254 and many other teams like it decided to only travel through the tunnel, and they played magnificently. (My team pretty much decided that going over the bump that year was pretty much imperative for success.) 469 didn't even plan on switching between zones at all!
John Bottenberg - University of Michigan '14 - Microsoft
FLL Team "Dark Matter": 2003-2005
Robofest Team "Dark Matter": 2005-2008
Team 67 Programmer: 2007-2010
Team 3322 Programming Mentor: 2012-2014
Team 2930 Engineering Mentor: 2015-????
Unread 31-01-2012, 10:18
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Agree with JABot67. In 2010, out team theorized that the tunnel would be too easily dependable to bother even designing the robot to go through. We were able (and fairly effective at) traversing the bump. As we all know, the tunnel did not get defended very much at all, and teams (like 254) used it with no problem.
This year, we have elected to go over the bump. Why? We again think (and probably incorrectly) that the bridge will be too easy to defend. Also, we want to be fast, and lining up with and crossing the bridge is not "fast."
Unread 31-01-2012, 10:52
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
In 2010 we couldn't go over the bump (well...we could, but it was difficult for us. We did it once in an off-season event at Kettering Kickoff) which we thought might cause us trouble since it seemed that one tunnel would be easy to defend. It seems like we rarely were defended from the tunnel - even in eliminations on Newton field. This year, there will be two bridges to cross - one of which can't be defended without penalty...you can't touch the opposing alliances bridge or robot in contact with the bridge. That being said, I also agree that it's possible to design for crossing the barrier much quicker than the bridge. It's really up to the team to decide if the reward for being able to cross the barrier is worth the effort of design a robot that can do it.
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
Unread 31-01-2012, 11:07
Joining the 900 Meme Team
FRC #0079
Because there may be designs which allow you to be more effective at one task by forgoing another task. Take 469 in 2010 as an example, how many times did they cross the bumps OR travel through the tunnel? It netted them 4 blue banners and a CMP finalist medal.
Strategies can sometimes call for other systems to be sacrificed.
