Go to Post 1114 is the definition of what a FIRST team should be. For anyone to say otherwise is disgusting to me. - Andrew Schreiber [more]
Unread 30-01-2012, 22:47
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: pic: Team 1296 teaser!!!
Originally Posted by BlacksmithWoods View Post
Cool, looks like your CIM motor limit is almost used up. What motors are you planning on using to pick the balls up and fire your launcher, if you are using a launcher. Also, how are you going to avoid the penalty of herding more than 3 balls at once. Once it is inside your frame it is considered to be "herded".
We are using AndyMark and FP motors on the launcher wheel. The conveyors will run backwards to reject balls as well as pull them in.
Unread 31-01-2012, 21:25
Robert Voorhis's Avatar
Robert Voorhis Robert Voorhis is offline
FRC #3481 (Bronc Botz)
Robert Voorhis has a spectacular aura aboutRobert Voorhis has a spectacular aura about
If you can only possess 3 balls at any given time, then how do you plan on controlling 4 different input systems?
If one always tries, one shall always succeed.
Cut once measure twice.
Unread 31-01-2012, 23:09
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Theyre all independently controlled. They dont have to intake balls so its pretty easy to control how many they posses.
