Go to Post So, in the good old FIRST spirit, let's all start brainstorming and sharing ideas, ok? :D - LauraN [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 27-01-2012, 14:56
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
LED Ring Light
It needs 12V power to work so can we just hook it up the the power distribution board?
Unread 27-01-2012, 16:09
Re: LED Ring Light
The wires are a little too skinny to work well in the Power Distribution board (and they're too small for a 20 Amp breaker, but there's not much you can do about that). I'd use a small section of the pale green terminal strip from the Kit of Parts to connect red and black wires of the appropriate gauge from the PDB to the ring light wires.
That will power the light full time. I don't know if you want to do that. Our practice drivebase has the camera light connected to a Spike relay module so we can turn it on and off on demand.
Unread 27-01-2012, 16:14
Re: LED Ring Light
so just make the wire that comes with it shorter and use what gauge wire to connect it to PDB
Unread 27-01-2012, 16:27
Re: LED Ring Light
See <R44> for the chart of which wire gauge to use for circuits protected by the various snap-action circuit breakers.
Unread 27-01-2012, 17:11
Re: LED Ring Light
srry for sounding stupid but our electrical mentor will not be here tonight
so we need 12 gauge wire then?
based on this
http://www.134team.org/docs/frcManual/GameRobot4.pdf
Unread 27-01-2012, 18:05
MCahoon MCahoon is online now
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: LED Ring Light
The real decision is made by the robot inspector at a regional, but your light ring should be defined as a custom circuit or wired as a branch circuit.
Good luck with your robot.
Unread 27-01-2012, 22:16
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: LED Ring Light
based on this
Originally Posted by MCahoon View Post
The real decision is made by the robot inspector at a regional,....
Which very possibly will be me...
Refer to <R44> on page 24 of the document you linked to (and you probably want to start referring to a copy from the usfirst.org server to make sure you are always using an up to date copy) if the ring light is connected to a 20A breaker on the power distribution board, then it can be connected with 18AWG wiring.
Run the 18AWG wire up to a point close to the light, and then splice to the wires that are part of the light. Make sure you use a mechanically robust connection, such as a crimp butt splice, soldering, or the terminal strip from the KOP (which you can cut down for just the number of terminals you need).
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 28-01-2012, 14:49
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: LED Ring Light
In the world of vehicle electronics crimp butt connectors are not considered robust. By reputable automotive electricians they are often referred to as emergency or temporary connectors or guaranteed failure points. For those that masquerade as "professional" technicians that use them they are referred to as job security.
The best ways in my opinion, to join the gauge of wire that normally is attached to the ring LEDs to the 18 ga wire would be to:
A. Solder them and cover them with adhesive lined heat shrink.
B. If you don't want to solder is to use a un-insulated parallel crimp connector and cover it with adhesive lined heat shrink. Even then I'd suggest soldering.
Those 2 methods meet the OEM level conditions for joining wire of different gauges or a splice of wire of the same gauges for either Ford, GM, Chrysler, Navistar (International) or Paccar (Kenworth and Peterbilt) depending on who's service literature you consult (with the solder in the second method).
Unread 30-01-2012, 16:31
Jeff Pahl's Avatar
Re: LED Ring Light
Properly sized and installed crimp butt connectors are considered robust enough by NASA for use on spacecraft (per NASA-STD-8379.4). In fact, they are even acceptable with multiple wires entering one end of the splice. As always, the important thing to remember is "properly sized and installed".
My number one preference is always a properly done soldered splice connection, with heat shrink. Again, the important thing is "properly done", which means some sort of mechanical joint between the two wires prior to soldering, such as a hook splice or Western Union splice. Proper wire tinning. Solder not wicked up under the insulation.
What I was trying to get across in my original posting was that approaches like just electrical taping the two wires together are not "mechanically robust".
One of the biggest things to watch out for in any wire splice is to not damage the conductors when stripping the wires. It doesn't matter how good the splice is if the wire breaks off in your first match. And when it breaks inside the heat shrink tubing you applied over the splice (or inside the big sticky gooey wad of electrical tape you had someone gob over the connection when you were done), the wire won't necessarily fall off and be obvious why your light (or whatever) is not working. Or works intermittently.
Unread 30-01-2012, 22:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: LED Ring Light
Cheap butt splices crimped with a simple pliers-like crimper is about as worthless as Mr. V asserts.
High-grade butt splices exist, and when used with the proper crimper, can exceed the reliability of the original wire, without solder.
It all depends on what you mean by butt splice, eh?
Unread 31-01-2012, 00:32
Mr V's Avatar
FRC #5588 (Reign)
Re: LED Ring Light
Yes but NASA doesn't use the insulated crimp connectors you'll find at your local hardware or auto parts stores and many FIRST Teams do. I should have been more clear that I was referring to those type of crimp butt connectors. Although they exist most people will be unable to locally obtain versions that are properly sized for splicing anything other than 2 wires of the same gauge. Either way the vinyl insulated connectors are next to impossible to determine if they have been properly installed (the "pull" test is not valid and may compromise a connection that was good) and most tools available at the same place that you buy those connectors are not capable of installing them properly. The insulated vinyl connectors are also known for cutting strands of the wire leading to the eventual failure of the wire.
Unread 16-02-2013, 10:45
Sargon2335 Sargon2335 is offline
FRC #2335
Sargon2335 is an unknown quantity at this point
Re: LED Ring Light
My team is trying to hook up the ring light. I already have a terminal strip in place, but we do not know which side is positive and which is negative. I have looked on andymark, the vendor's website, and many different threads on chief delphi. Do you guys know which wire is which? I was assuming the one that is tinted copper is positive, but I don't want to plug it in until I know for sure.
Unread 17-02-2013, 00:51
Re: LED Ring Light
Don't worry. It's okay if you connect the LED ring light backwards temporarily while you determine which wire is which. You won't break anything if you put battery voltage across it in the wrong direction.
(It'll break if you put too much voltage across it in reverse, but that would be just as bad for it in the forward direction too.)
