Re: 500s motors on relays?
Fair point, I forgot that the Spike fuse could trip too. It's been a while since I've driven a motor with one, as you might imagine. (And you may replace the fuse on the Spike powering the compressor.)
I knew the fuse for the compressor can be changed, heck its the only spike we use. But this year for our ball pick up we wanted to power the three motors (2 PG71, 1 AM500s) with spikes because there is no need to control the speed because they are in custom gear boxes. So basically it should work. Like I said before if the motor stalls then there is a huge problem.
ATM fuses are rated to open in 500 ms with 135% overload. That's 27 amps for those without a calculator. Every overload over 20 amps weakens the fuse so that even repeated surges of 22-25 amps will likely open the fuse at some point in time.
We ran the two 550's on our roller claw last year through Spikes and never had an issue. With proper gearing you SHOULD be alright as far as current draw goes. We plan on running a 500-series sized motor through a spike again this year but are prepared to swap it out to a Victor if needed.
I never like putting a motor which can draw (vastly) more than 20A in line with a 20A fuse under any circumstances. Even if the motor *shouldn't* stall in its application, I would not feel comfortable.
The fuse / breakers are there to protect the motor and wring. So depending on the mechanism, I can see an advantage. If it is designed to never need more than 10 amps, at a constant speed, the fuse will (should) prevent a smoked motor in case of stall.
#7
Dad,
While that is generally the case, the fuse on the Spike is meant to protect the contacts of the relays inside. The rule about using a breaker came from a manufacturer's recommendation for the Spike driving a compressor. |
