Go to Post I have postulated a theory that it is due to a resonance between gravity waves and the color purple. - petek [more]
Unread 31-01-2012, 01:22
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
500s motors on relays?
I know that FP motors aren't allowed to be run on a spike. My question is can any other 500 series like a BaneBot or AM, allowed to run on a spike? I'm assuming they can because I haven't read anything saying the can't in the manual. Plus, I have never done this since joining FIRST. All answer would be helpful thanks!
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 31-01-2012, 01:24
Re: 500s motors on relays?
According to the rules they can, but be aware that you cannot replace the 20A fuse of the Spike for these circuits and these motors draw much more than 20A at stall.
Unread 31-01-2012, 01:32
AKA: Pat Miller
I forgot about the fuse part. But if the motor stalled in our application, then we have some serious problem. I guess well have to try it out on the practice robot.
Unread 31-01-2012, 02:15
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
A 20A fuse wont usually won't "pop" unless the motor draws 40A for about 1 second. If i remember correctly they can handle the motors 80A stall current but only for a fraction of a second.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 31-01-2012, 02:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Trip characteristics are on the specification sheets for the circuit breakers.
20 A and 30 A: Snap Action VB3
40 A: Snap Action MX5
Unread 31-01-2012, 03:14
AKA: Pat Miller
He was talking about the fuses on the spike itself. Which you cant replace.
Unread 31-01-2012, 03:22
Fair point, I forgot that the Spike fuse could trip too. It's been a while since I've driven a motor with one, as you might imagine. (And you may replace the fuse on the Spike powering the compressor.)
Unread 31-01-2012, 03:35
AKA: Pat Miller
I knew the fuse for the compressor can be changed, heck its the only spike we use. But this year for our ball pick up we wanted to power the three motors (2 PG71, 1 AM500s) with spikes because there is no need to control the speed because they are in custom gear boxes. So basically it should work. Like I said before if the motor stalls then there is a huge problem.
Unread 31-01-2012, 07:55
ATM fuses are rated to open in 500 ms with 135% overload. That's 27 amps for those without a calculator. Every overload over 20 amps weakens the fuse so that even repeated surges of 22-25 amps will likely open the fuse at some point in time.
Unread 31-01-2012, 08:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We ran the two 550's on our roller claw last year through Spikes and never had an issue. With proper gearing you SHOULD be alright as far as current draw goes. We plan on running a 500-series sized motor through a spike again this year but are prepared to swap it out to a Victor if needed.
-Dustin Benedict
Unread 31-01-2012, 08:53
Jared Russell's Avatar
Taking a year (mostly) off
I never like putting a motor which can draw (vastly) more than 20A in line with a 20A fuse under any circumstances. Even if the motor *shouldn't* stall in its application, I would not feel comfortable.
Unread 31-01-2012, 09:29
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
The fuse / breakers are there to protect the motor and wring. So depending on the mechanism, I can see an advantage. If it is designed to never need more than 10 amps, at a constant speed, the fuse will (should) prevent a smoked motor in case of stall.
Unread 31-01-2012, 10:37
Dad,
While that is generally the case, the fuse on the Spike is meant to protect the contacts of the relays inside. The rule about using a breaker came from a manufacturer's recommendation for the Spike driving a compressor.
