Go to Post I'm exceptionally bad at taking my own advice, is all. - Libby K [more]
Unread 30-01-2012, 23:28
rhp3794 rhp3794 is offline
rhp3794 is an unknown quantity at this point
Question programming joystick buttons
I've already made a program with basics for the team robot, We try to test it, the Joystick axis x and y work well, but button 1 which is programmed for the cannon didnt work, i connect Isochronous terminal with the unbundle by name, connected in buttons terminal in joystickget with an indicator of T/F
the three together, and didnt work, what do i have to do??
Unread 31-01-2012, 01:25
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: programming joystick buttons
I couldn't make out exactly what you are trying to accomplish but this is what I got out of it...
1. You have a button, in this case button one or on a joystick usually the trigger, which is supposed to shoot a cannon.
2. You've stated that you have connected the button up to a true/false indicator and when you run code it doesn't work?
I would assume that your joystick is bad... Although that is pretty rare...
Unread 31-01-2012, 07:55
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Here's a basic Joystick button layout.
If you are looking to light up an LED, replace the case structure with a boolean indicator.
