Go to Post Test your code and your assumptions. - ShotgunNinja [more]
Unread 31-01-2012, 10:25
stcywlkr stcywlkr is offline
FRC #2640
stcywlkr is an unknown quantity at this point
crio not communicating with digital io module/sidecar
I cannot seem to get the crio to communicate with my digital io module, the blinking light on the sidecar representing the communication from digital i/o module is not blinking. Also, when I set a relay to forward or reverse, light for relay does not turn green or red. At a loss, any help would be greatly appreciated. I am able to control motors using jaquars and pwm but that is analog and going through a different card. Is there anything special that needs to happen to configure the digital io module/card. I have it in slot 2 of the crio.
Unread 31-01-2012, 11:25
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: crio not communicating with digital io module/sidecar
Please search the forum before creating a new thread. There are now at least 20 of these threads that I have seen.
If you read the manual, you will find that all of the cables that shipped were defective. On the first KOP website, there is a link to fix the DB37 cables that shipped.
Unread 31-01-2012, 14:01
FRC #2640
Sorry, I did search and had found the threads regarding the faulty ribbon cables...we are not using that cable...using the db37 cable from last year.
Unread 31-01-2012, 14:03
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
threads all over the place
2 problems.
DB37 cable
digital I/O goes in slot two, new arrangement for this year
Ed Barker
Unread 31-01-2012, 15:23
FRC #2640
Right...I have the module in slot 2 and I am not using the faulty ribbon cable. Any other recommendations? This is pretty frustrating because I am not one of those guys who fails to read directions and I thought I had done my homework here. Had already identified changes this year regarding the new slot for digital I/O and the faulty ribbon cable. Applied all of the applicable updates, etc. Currently at a loss here. Any help would be greatly appreciated. Several references to alot of other posts, are they in a different forum other than control system?
Unread 31-01-2012, 22:27
How are you providing power to your Digital Sidecar? Are the BATT and +5v LEDs lit?
