Go to Post "And that right there is the Sharpie line between right and wrong. Guess which side you cut on?" - Cypher [more]
Unread 31-01-2012, 11:21
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Re: Jaguar Powers motor with no signal!!!!!
we didnt wire the si card in but the jags should be neutral with no signal right???
Unread 31-01-2012, 11:33
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Check to make sure you wired the jag correctly - if you hooked the motor inputs to power, and the motor to the power inputs, this will happen (and the Jag will be fried).
Unread 31-01-2012, 15:02
pfreivald's Avatar
AKA: Patrick Freivald
You know what stinks? Doing that to all four jags on your drive train at the same time!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2012, 11:34
Shaun Coon's Avatar
FRC #2487
we are only using 2 jags with our drivetrain since there are only 2 CIMS on our drivetrain. we figured out the problem was that i mounted them wrong which led me to wire it wrong dont worry the jags and cims both still work!!!
Unread 02-02-2012, 14:33
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
The Jaguar may still work, but over time you may see the effects of powering the motor side. Be sure to mark that Jag so that you can tell it apart from the others.
If it acts up in the future, it is most likely from damage it sustained when connected improperly.
-David
Unread 31-01-2012, 11:40
justinj justinj is offline
AKA: JUSTIN JAMES
FRC #1806 (S.W.A.T)
justinj is an unknown quantity at this point
if your jags are getting power and they are neutral they should have an amber light
