Go to Post If this information is not 100% correct, you should follow the default advice I have for when anything goes wrong: Blame the Programmers - IKE [more]
Unread 31-01-2012, 11:13
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Jaguar Powers motor with no signal!!!!!
Yesterday i was wiring our robot and i wanted to test to make sure that the Jags had power and when I powered up the robot only one Jaguer started running for some reason. Does anyone know why this would happen????? NO ONE WAS INJURED OR HURT!!!
Unread 31-01-2012, 11:15
justinj justinj is offline
AKA: JUSTIN JAMES
FRC #1806 (S.W.A.T)
justinj is an unknown quantity at this point
Re: Jaguar Powers motor with no signal!!!!!
were all if the jags have the light on them on? or were they not getting any power at all?
Unread 31-01-2012, 11:18
Shaun Coon's Avatar
FRC #2487
no quite the opposite they supplied power through the jags and powered our CIMS with no signal but only one jag did this i dont know why.
Unread 31-01-2012, 11:21
Shaun Coon's Avatar
FRC #2487
we didnt wire the si card in but the jags should be neutral with no signal right???
Unread 31-01-2012, 11:33
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Check to make sure you wired the jag correctly - if you hooked the motor inputs to power, and the motor to the power inputs, this will happen (and the Jag will be fried).
Unread 31-01-2012, 11:40
AKA: JUSTIN JAMES
FRC #1806 (S.W.A.T)
if your jags are getting power and they are neutral they should have an amber light
Unread 31-01-2012, 15:02
pfreivald's Avatar
AKA: Patrick Freivald
You know what stinks? Doing that to all four jags on your drive train at the same time!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2012, 11:34
Shaun Coon's Avatar
FRC #2487
we are only using 2 jags with our drivetrain since there are only 2 CIMS on our drivetrain. we figured out the problem was that i mounted them wrong which led me to wire it wrong dont worry the jags and cims both still work!!!
Unread 02-02-2012, 14:33
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
The Jaguar may still work, but over time you may see the effects of powering the motor side. Be sure to mark that Jag so that you can tell it apart from the others.
If it acts up in the future, it is most likely from damage it sustained when connected improperly.
-David
