Go to Post Why dress to impress when you can speak to impress? - Joe Matt [more]
Unread 30-01-2012, 14:52
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Batter Mounting Rules???
Are there any specific rules for the mounting of the battery within the robot? We are assuming it just needs to be held securly so it doesn't fall off etc during the competition?
jalmos
rookie team #4166
Unread 30-01-2012, 15:43
Re: Batter Mounting Rules???
There are no actual Rules that I can find, but there are plenty of guidelines and lots of good advice.
You're right, you don't want it falling out during a match. Mount it securely.
Batteries are dense and heavy. Mount them low if you want to keep your robot's center of gravity low.
Make it easily accessible and easy to pull out without tugging on the wires, because you'll be changing it often.
Keep sharp corners and bolt ends away from it. You don't want something poking a hole in it.
Mount it in whatever orientation makes the most sense for you, but try not to put it upside down. Although it will function okay in any direction, if it overheats and starts venting you really shouldn't have the vents at the bottom.
Unread 30-01-2012, 18:41
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Make sure you mount your battery securely - it should remain in place even if your robot tips on its side, front, or back (especially with the bridges and bumps this year). If it falls out, your robot WILL be disabled on the field.
Unread 31-01-2012, 11:17
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
To Be Safe you should use the new battery holder that came in this years KOP. It actually goes inside where you grab it and wont let it move in any direction after you put the battery strap that came with it around the battery and what ever you are mounting it on
Unread 31-01-2012, 11:58
There are many ways to mount the battery safely and securely without using that battery holder. For example, 4 pieces of angled aluminum with 1+ Velcro straps going over the top of the battery works fairly well. Building a fairly deep plywood box with some form of holder on the top (say, Velcro) is another option.
I'm trying to remember what exactly my team used in 2005--IIRC, the battery was sandwiched between a frame member and a couple pieces of aluminum, strapped in with Velcro, and then locked in when we closed the hatch that allowed for access to the electronics. That battery wasn't going anywhere!
Unread 31-01-2012, 12:24
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Clarification on usage of Velcro. Don't be cheap on the velcro. Last year we used a 2" wide velcro strap, with an overlap velcro joint across the entire width of the front face of the battery (which was facing up). Of course, make sure the velcro strap itself is securely fastened to the rest of the robot.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
