Go to Post Thinking can be uncomfortable, but I always think that it is beneficial. - JaneYoung [more]
Unread 31-01-2012, 12:00
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Re: Shooter question
Originally Posted by IceStorm View Post
I noticed that your using a Quikrete tube on your lift mechanism. That is a really neat idea. What is the diameter on it and is there much slop around the ball because of it?
The diameter is labled "8 inches nominal". The ball will fall through the tube, but there is very little gap between the ball and the tube.
Unread 01-02-2012, 19:10
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
Were using two wheels attached together. A motor spins them and launches from the bottom, which gives more power and distance from the top in our tests.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 01-02-2012, 19:13
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
http://www.screamingchickens.org/videos.html
We are a rookie team too and this was our first prototype and it worked great for us. You might find if it was over kill once u see it but work well.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 01-02-2012, 20:19
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
or to have the same set up with a static or powered wheel at the top. any thoughts?
Well a powered wheel at the top would constitute a two wheel shooter which, in general, you WILL see much greater distance with. But, as you said, it is more complicated. The way I see it is that you should go one wheel and a sheet hood because we actually don't really need the large distances mentioned before! Aiming from more than half court would be quite the challenge, so do you really need a shooter that can go farther than that?
To note on the static wheel, do you mean free-spinning or fixed, e.g. non-spinning wheel? Having a static fixed wheel seems kind-of wasteful space and weight wise, also I'm not sure it would really even work! Just doesn't seem right...
For free-spinning, that's also a no go. I think you would get in a situation where the ball contacted the powered wheel, began to spin, and just twirled there spinning you're free spinning wheel with it!
+ on that one wheel with a hood, you also get some of that great, magical backspin
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 11-02-2012, 15:00
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
Using 2 wheels and one lexan sheet as a compression point would be good, 2 wheels help give it stability and will be more consistent.
