Go to Post heh...do the math! - MrForbes [more]
Unread 13-01-2012, 12:36
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Only 2 Gyros?
We want to put 3 gyros on this years robot, but the Gyro Open VI only says we can use 2. Is there a rule that we cant, or the code cant handle it or, is it just being weird.
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 13-01-2012, 12:44
There are only two hardware accumulators that perform the integration of the gyro rate to give position built into the fpga. If you want to just get the rate from the gyros, you can use analog vi. If you want angle from more then two gyros, you can write your own integration.
What do you want 3 gyros for?
Unread 31-01-2012, 13:52
adf0221 adf0221 is offline
FRC #1517 (Lumberjacks)
adf0221 is an unknown quantity at this point
Re: Only 2 Gyros?
If we added a second analog module in our crio would that enable us to use more then 2 gyros?
Unread 31-01-2012, 13:54
Re: Only 2 Gyros?
Unfortunately, no. The accumulators are only active on the first analog module.
