Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
Unread 27-01-2012, 12:11
striker's Avatar
striker striker is offline
AKA: Michael Walsh
FRC #0101 (STRIKER)
striker is an unknown quantity at this point
FIRST Team 101 Driving over the bump
Here is a video of us driving over the bump.
http://www.youtube.com/watch?v=2WV8Uw-5lqI
Unread 31-01-2012, 14:02
JPM0887's Avatar
JPM0887 JPM0887 is offline
FRC #1289 (Gearheadz)
JPM0887 is an unknown quantity at this point
Re: FIRST Team 101 Driving over the bump
What are you using to make it turn? Doesn't look like there are any casters or omni wheels.
Unread 31-01-2012, 14:05
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Any thought on stability when you go over? You get to a pretty steep angle when your center wheels are up on the barrier.
Unread 31-01-2012, 14:07
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Goes over pretty easy! How high up does the rest of your robot go? Are you worried about it being top heavy and tipping over at all?
Unread 31-01-2012, 14:11
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Looks (to me) as though the front open end of the robot is having some frame flex issues. The inside corners (ball intake opening?) seem to be angled down in relation to the outside corners on the front 2 edges of the chassis.
Do you have any plans to tie the frame together to prevent flex? If you don't, I suggest you look into it. A lot of frame flex will cause your axles to be out of alignment, which will also throw off where your wheels sit in the chassis, and can potentially cause driving issues and loosen chains.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
Unread 31-01-2012, 14:14
striker's Avatar
AKA: Michael Walsh
FRC #0101 (STRIKER)
We are using six wheel drive no casters or omni wheels.
For stability we plan to have our drivers go a little bit slower over the bump. and with everything else we have added to the robot since the video was taken it goes over the bump a little smoother
Unread 31-01-2012, 14:15
striker's Avatar
AKA: Michael Walsh
FRC #0101 (STRIKER)
The front open end is already stabilized. We noticed that right away too.
Unread 31-01-2012, 14:19
striker's Avatar
AKA: Michael Walsh
FRC #0101 (STRIKER)
We are going to go up anywhere from 50" to 55" at the moment with everything else we added we have not tipped over yet. If need be will make adjustments so it does not tip over easily.
