Go to Post No, no, no, it's a fire game. The pool is there in case of accidents. - artdutra04 [more]
Unread 31-01-2012, 14:11
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Re: FIRST Team 101 Driving over the bump
Looks (to me) as though the front open end of the robot is having some frame flex issues. The inside corners (ball intake opening?) seem to be angled down in relation to the outside corners on the front 2 edges of the chassis.
Do you have any plans to tie the frame together to prevent flex? If you don't, I suggest you look into it. A lot of frame flex will cause your axles to be out of alignment, which will also throw off where your wheels sit in the chassis, and can potentially cause driving issues and loosen chains.
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
