Go to Post My wife said if no one gets ahead no one gets left behind. - Koko Ed [more]
Unread 27-01-2012, 22:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Balls under the bumper
We first noticed this with our mecanum test bed which has last year years bumpers on it. Its bumpers are at 5 inches & the balls just compresses & rolls under it. Robot is around 40-50 lbs. The Locomotion bot is 119.9 lbs. (Don't ask how that happened ) It was unpowered & pushed to the ball. The ball compressed & started under the bumper. We stop when it was clear that it was not going to bounce off. We will play with it (oops investigate) more tomorrow.
Unread 28-01-2012, 11:50
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Red face Re: Balls under the bumper
This is strange. Our low bumpers do not eat balls anymore. Currently not even close. The balls still go right under the high ones.
Unread 28-01-2012, 12:59
commonsense commonsense is offline
FRC #3452
commonsense will become famous soon enoughcommonsense will become famous soon enough
What if you just make sure that your bumpers can't actually "control" the ball, hence make the bumpers as high as possible so that you can't actually have a ball catch under them. Thus when it comes to the bumper, weather in or outside the frame it will pass under. Thus no mater how hard you tried to grab it with the bumper it would pass under. I would consider that would not be being in control of a ball.
Unread 28-01-2012, 16:47
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
A bumper is 5 inches tall, and the bumper zone extends to 10 inches. Thus, the highest you can elevate the bottom of the bumper off the ground is 5 inches.
Unread 31-01-2012, 13:26
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
We also played with (oops...investigated ) our 2011 bot on mecanum wheels. We had a 5 inch bumber height, but we realized that because the bumper is curved on the bottom, that curve aided in sucking in the ball. I believe you need the center of the ball to be higher than (or at least equal to) the midline of the lowest pool noodle in your bumper. This will prevent the curve of the bumper from "collecting" the ball. Unfortunately, it may also prevent you from driving over the midfield bump.
With a little geometry, you can calculate a desired bumper height of 2 and 3/4" maximum. If your bumpers are any higher than this, you will want to look into some sort of deflector on the non-intake sides of your bot.
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 31-01-2012, 14:19
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I wonder how bumper cover material affects this? Seems to me that the balls get "sucked under" because the friction between the ball and the cloth covered bumper is pretty high. I wonder if a smoother bumper cover material (vinyl?) might change things.
Unread 31-01-2012, 14:34
FRC #3452
The point was not that the ball would have full clearance (8 in.), but that every time it came to a bumper, it would be sucked under. If at 5 in. it always passes under (weather in or outside the frame), you wouldn't have any control over it, thus complying with the rule. However you want to be sure that it will always go under 5 in.
Unread 31-01-2012, 20:38
mrlg220's Avatar
mrlg220 mrlg220 is offline
FRC #3464 (Sim-City)
mrlg220 is an unknown quantity at this point
I expect to see some robots with high bumpers ride up on the balls and roll over this year without a deflector of some sort... or, get pushed over by those with low bumpers... A la Breakaway
Unread 01-02-2012, 16:07
jon-s's Avatar
jon-s jon-s is offline
Lead Designer
FRC #3335
jon-s is an unknown quantity at this point
Originally Posted by 1493kd View Post
I am interested to see how hard/liberal they are with the penalties for getting a 4th ball "into" your robot. I think some teams with 3 balls already in possession are going to end of playing dodge ball on the field in hopes of not gettings a penalty.
In the section of the rules about the game fouls, it says that fouls caused by the opposing alliance will not be counted. Nothing against one of your team-mates jamming a ball into your robot.
Jon. S
Unread 01-02-2012, 16:09
jon-s's Avatar
Lead Designer
FRC #3335
If the bottom of the bumper is above the centerline/middle of the ball (above 4 in) then the balls are much more likely to get caught under the bumpers.
Jon. S
