Go to Post Hack saws are for hack work, the kind we don't do. - sanddrag [more]
Unread 31-01-2012, 15:14
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
Re: No clue where to start on Programming...
Each time I try to Deploy the new code onto the cRIO, a Conflict Resolution window appears. Below will be a Screenshot of the window.
If anyone knows why this is occuring and can help fix this, please reply. ASAP.
http://imgur.com/lTOrP
Unread 31-01-2012, 15:23
This is a warning, not an error. The ways to stop it from happening are much slower than just clicking OK. There are no ill effects from just clicking OK.
Unread 31-01-2012, 15:27
Lead Programmer
That is a MAJOR relief, thank you.
Unread 31-01-2012, 16:37
Lead Programmer
I have run into yet another problem.
In LabVIEW, I cannot get our other 2 motors to respond to the programming. I've tried with 4-motor and 2-motor drives, and nothing works. We've checked all the hardware and wirings, with nothing working. If anyone can help, it would be great.
I made sure I had everything edited properly in Teleop, Begin, and Finish vi's.
Motors 3 and 4 were wired into PWMs 3 and 4, with neither working. However, 1 and 2 DO work, but because they were pre-programmed, I have no clue what the problem could be.
A simple schematic would be great. A screenshot, anything really.
In need of desperate help.
Unread 31-01-2012, 22:59
For your motor speed controllers, are you using Jaguars or Victors?
What is the light on the speed controller showing, both before and after you Enable the robot using the Driver Station?
Unread 01-02-2012, 10:51
Here's what your Begin should look like and the original drive code must be gone.
Things to watch out for include:
  • Making sure you don't have two different drive trains defined
  • Making sure the drive name is correct in Teleop
  • Make sure your PWM's are all unique
If you get Begin right, then your Jaguars should stop blinking when the robot is Enabled, at least from a code perspective.
That doesn't mean your PWM cables aren't reversed or something.
Unread 01-02-2012, 19:24
Lead Programmer
Thank you so much for telling this! I did NOT know I had to delete the original code! I'll try that tomorrow and tell you how it works.
To answer the previous question, all 4 Jaguars blinked a constant yellow.
-The 2 motors that ACTUALLY worked then displayed a solid green or red, depending on their direction of travel.
Unread 02-02-2012, 16:15
Lead Programmer
I did exactly as you said, I checked and made sure I deleted ALL original code, and I made sure the names were exactly the same. I followed the picture exactly in LabVIEW and the two additional motors are STILL not spinning.
Unread 02-02-2012, 16:39
Lead Programmer
http://imgur.com/pHaX7 --- Teleop.vi
http://imgur.com/hic4V --- Begin.vi
http://imgur.com/mE9fR --- Finish.vi
As you can see, I removed the original code, and then added in my OWN code.
I can successfully deploy the robot code to the cRIO.
Then, I switch over to the Classmate and I get Robot Communication and Code.
However, when we move the joystick on our controller, motors 3 and 4 DO NOT respond with the code. There is no signal being sent to either Jaguar.
Please help. If you know what the problem is, please tell. We are desperate right now. It's not our hardware or wiring. The only solution I can think of is the programming itself. So please explain what my problem is.
Unread 02-02-2012, 16:45
I see nothing immediately wrong with the code. How are you deploying it to the robot?
When you say you "switch over to the Classmate", what exactly does that mean?
Unread 02-02-2012, 16:51
Lead Programmer
I have a Host Computer with LabVIEW downloaded onto it, and the Host computer is what I use for programming. I then deploy the code by pressing the right-facing arrow on-screen. Switching over to the Classmate I mean unplugging the Host computer (Ethernet chord) and plugging into the Classmate (again with an Ethernet chord).
Unread 02-02-2012, 16:54
That would be bad, since the white arrow only runs in debug mode and automatically shuts down the cRIO code when your laptop disconnects.
Rebooting the cRIO restores previous code, which obviously is a two motor version.
Either get a second Ethernet cable and go through a switch, so they can both remain plugged in, and/or download the code permanently.
Unread 02-02-2012, 17:05
mswalker mswalker is offline
FRC #2583 (Westwood Robotics)
mswalker is on a distinguished road
If you installed everything from the LabVIEW USB you should have the FRC Driver Station program on your host computer. You can start that and run it in place of the ClassMate. If you are plugging your ethernet cables into the Wireless Bridge, you can plug both your host and classmate in at the same time. (Just make sure your host has a unique IP address ie not 10.te.am.6 or 10.te.am.5)
http://team2583.org
Unread 02-02-2012, 16:58
Lead Programmer
We tried reversing the PWM cables, and our battery has full volts.
However, we have NO lights on the Sidecar, and it IS the one provided this year.
That being said, 2 of our 4 motors work properly. As if they were "pre-programmed"
Unread 02-02-2012, 17:04
Lead Programmer
If you go to the Project Explorer -> build specifications -> FRC Robot Boot-up deployment and right click Boot-up Deployment, you should see an option "deploy." Would this work to permanently deploy the code onto the cRIO? If not, is there a way to PERMENANTLY deploy any new/changed code to the cRIO while using a Host computer?
