Go to Post Well, there goes our bare aluminum corner tracking full field navigation system... - Whippet [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 24-01-2012, 17:28
wardawg's Avatar
wardawg wardawg is offline
FRC #2961
wardawg is an unknown quantity at this point
Smile need help findinga conveyor that can be modified to hold a ball
were trying to use a coveyor in our design to guide the ball into our shooting mechanism sort of like in the 2009 FRC competion. But we cant seem to find the right conveyor. please help links, companies, or numbers to other teams that are using or have used this will help. thanks! =)
Unread 24-01-2012, 17:32
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: need help findinga conveyor that can be modified to hold a ball
I doubt you'll find an off-the-shelf conveyor that'll work... every conveyor system i've seen on a robot has been something the team has designed and built themselves.
Figure out the material you want to use on the conveyor (do some searching on here, there is plenty of discussion). Figure out what you want your rollers to be made of, how you're going to mount them, and how you're going to power them. Put it all together and you have a working conveyor!
Unread 24-01-2012, 20:31
DonRotolo's Avatar
Back to humble
FRC #0832
Also look at 2009 robot photos for ideas.
Some teams use Urethane Belting as the conveyer, two-to-five strands in parallel might be effective. For end pulleys, some teams use 1.5" - 2" PVC pipe, driven by a relatively slow motor (i.e. through a reduction gearbox) at the top & bottom.
The belt grabs the ball and rolls it up the robot, on a plate of Lexan placed about 6-7" from the belts.
Of course, there are many materials: We've used cloth, shelf sticky-foam-liner, urethane belting, even rope.
Prototype!
Unread 26-01-2012, 09:13
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
we used pneumatic tubing....
cut to length then melt them together with a soldering iron
Unread 26-01-2012, 09:36
craigcd's Avatar
craigcd craigcd is offline
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
Try these guys
http://www.intralox.com/
They gave away free samples at the kick off at Stennis Space Center
This is what we are using and it works great
Unread 26-01-2012, 09:42
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Originally Posted by craigcd View Post
Try these guys
Which of their products are you talking about? Thanks!
Unread 26-01-2012, 10:13
2544HCRC's Avatar
2544HCRC 2544HCRC is offline
FRC #2544 (HCRC)
2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about
We are using 6" belting from a local industrial supply house. It was an extra piece and they are having someone join the ends for us. As for pulleys we are using a piece of 4" sewer pipe with ends made from solid PVC from McMaster Carr. The plastic will be turned down in a lathe to fit in the pipe and a 5/8 hole bored in the center for one of the anodized shafts that came in the kit. We are driving the conveyor with a urethane belt on a drive pulley. We're stuck on a gearbox. We were going to use an AndyMark box but they are out of stock again and I don't think we can wait and risk them being out of stock again.
Unread 27-01-2012, 09:45
craigcd's Avatar
Series 1100 flush surface straigh belt .62 pitch rubber coated top surface 3" wide and we are using 3" sprockets Send me a PM
Unread 27-01-2012, 11:55
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
Can you make custom lengths? or do you order in the lengths you need?
What is the cost of the material?
Thanks
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 30-01-2012, 15:41
andrewthecow's Avatar
andrewthecow andrewthecow is offline
FRC #3753
andrewthecow is an unknown quantity at this point
If you're asking about the Intralox stuff, team 3753 is using it as well. I'm not sure about the pricing because it was free to teams at the Stennis space center kickoff(though I'm sure we'll need to find out in order to do a BOM), but i think it's around $20/foot. It's really high quality commercial stuff and they custom make the shafts that you need. It is also really easy to "break" apart and rejoin it so that you can adjust the length easily.The only inconvenience we've run into is that it doesn't hold tension very well and needs a solid backing behind it(i.e. sheet metal, plywood, plastic sheeting, anything that can be rounded off where it won't get caught on the belt).
Unread 30-01-2012, 15:49
AdamHeard's Avatar
Lead Mentor
You used actual pneumatic tubing? You really don't want to do that. It's a pretty horrible material for conveyor belting.
Unread 30-01-2012, 21:58
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Lynxmotion treads work well:
http://www.lynxmotion.com/c-94-tracks.aspx
Not super-cheap, but very sticky surface and smooth running with little drag on the motors.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 31-01-2012, 15:25
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
our team is using several strands of surgical tubing running in loops next to eachother (like several small conveyer belts). So far we have had problems with them stretching too much, but it looks like as long as they have enough tension they should work well.
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
