Go to Post Seating is limited. Be sure to apply deodorant and brush your teeth. - Wayne TenBrink [more]
Unread 31-01-2012, 16:06
iHuman's Avatar
iHuman iHuman is offline
FRC #1403 (Cougar Robotics)
iHuman is an unknown quantity at this point
Robot Connection Error
After reinstalling the firmware for the cRio in order to solve a low-memory error, we are getting a connection error durring deployment, saying that we couldn't connect to the target. Has anyone else had this problem, or know how to solve it?
Unread 31-01-2012, 18:26
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Robot Connection Error
make sure you are hooked up to that wifi and the ip adress in the labview code is correct. If you are using a tethered connection, make sure wifi is disabled
