Go to Post FIRST is really a community, we only compete on the field. - InFlight [more]
Unread 30-01-2012, 15:53
detruby detruby is offline
Dave Truby
AKA: Dave Truby
FRC #4145 (Wolf Pack)
detruby is an unknown quantity at this point
Smart Dashboard - SquareTrackerExtension quit unexpectedly
Running Smart Dashboard extension (example) SquareTrackerExtension - after a short time dashboard crashes with
quit unexpectedly while using the libopencv_code.2.3.dylib plugin.
I am running on mac OSX. I have attached the osx crash report.
File Type: txt smartdashboard-crash-report-20120130.txt (88.6 KB, 19 views)
Unread 30-01-2012, 22:33
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Smart Dashboard - SquareTrackerExtension quit unexpectedly
[speculation based on an observation from my last meeting that I never got around to investigating]
Could you run it and monitor your memory usage? I think the SmartDashboard has a memory leak. If so you should notice some very drastic accumulating memory usage.
EDIT: Could be reading the crash report wrong, but I think I might be right:
Physical Memory: Page Size = 4k, Total = 4096M, Free = 9M
<snipped>
TOTAL 1.4G
Unread 31-01-2012, 16:13
Dave Truby
AKA: Dave Truby
I started the osx activity monitor and then ran the smart dashboard. after adding the SquareTracker widget to the dashboard - virtual memory continued to climb until it ran out - then crashed. From watching the memory while changing what the camera sees - it appears to only climb while objects are found (red border is drawn). I am attaching the photo (I hold a color print out in this front of the camera) and the SquareTracker source (I made a couple changes so it tracks better with the photo).
PS. before doing the test above, I deleted all libraries and source I was using and re-downloaded to make sure I had the latest versions of the smart dashboard (and the internally related projects) and wpilibjava. For all lines of java I changed in SquareTrackerExtension.java, I left the original line (commented out) - if that helps.
Dave Truby, team 4145 mentor
Unread 10-02-2012, 08:01
Dave Truby
AKA: Dave Truby
I see a fix was committed to the trunk. I updated from the trunk, re-built and tested. It runs a lot longer before running out of memory.
Dave Truby
