Go to Post Strive for excellence in everything you do, but also recognize it in others when you see it, rather than try to drag it down. - Joe G. [more]
Unread 31-01-2012, 16:31
Mashby77 Mashby77 is offline
FRC #4237
Mashby77 is an unknown quantity at this point
Reflective Tape
My team is trying to test the camera, we want to find the reflective tape with it. the question is are there any suggestions for what color the board that we put the tape on should be. currently we have a set of blue designed stuff. we thought white would work well but it is really close to the color of the tape.
Unread 31-01-2012, 16:36
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Reflective Tape
I say you should get as accurate as possible - read section 2.2.4 for details on what will actually be on the field.
Unread 31-01-2012, 16:44
Nate Laverdure's Avatar
FRC #2363
Re: Reflective Tape
See field drawing GE-12012, Backboard Top:
Material:1/2" thick Smoked Polycarbonate, 713 Gray
Unread 31-01-2012, 16:45
FRC #4237
Re: Reflective Tape
-the only problem we are gonna have with that is the blue design. our backboards arent clear like they are in the real arena. our plan is the reflective tape is gonna have the black tape like the diagram shows. we werent sure if the blue design would throw the camera off. our counter to that was to tape up some kind of alternate colored paper. thats where my question applys.
Unread 31-01-2012, 16:52
Mentor, LRI, MN RPC
Re: Reflective Tape
That all depends on how you're detecting the retro-reflective tape. This tape is like like what you see on road signs at night - it reflects light back towards the source (on the road, that means reflecting your headlights back towards your car so you can see the signs, instead of up into the sky). In order to get it to work the best, you'll need to shine some sort of light up at the target for the camera to be able to more easily pick it out.
If you're shining a blue light at the target, then your blue background could cause a problem. If you're shining a red light at the target, I wouldn't worry about it.
Unread 31-01-2012, 17:05
FRC #4237
Re: Reflective Tape
k thanks Mr.Stratis that information really helped. That perspective completely left my mind. Thanks again and hope to talk again soon
Unread 31-01-2012, 19:10
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Re: Reflective Tape
We've done a ton of research into how to do this, and every method ended up with the same result; It works, but intermittently, and not with alot of accuracy. Overall, we've decided it's not worth it, and we're relying on the human element for aiming. If you find a good, reliable method, lplease let me know. I'd appreciate it.
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
