Go to Post "Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." - Albert Einstein - Edward Debler [more]
Unread 31-01-2012, 16:46
TehNovak's Avatar
TehNovak TehNovak is offline
Skaian Programmer
AKA: Doc Scratch
FRC #4053 (Robot Ascension)
TehNovak is an unknown quantity at this point
Jaguar is unresponsive
We are having some difficulties with our programming and the brains/motors to our robot. We finally got our computer to talk to our cRIO and the programming is working (eh...) but our Jaguars are unresponsive. They are blinking yellow/orange (its hard to really tell the color) and the motors wont run when we use the joystick. we are just trying the arcade drive example to test and see if its working, and it isnt. any help/advice is apreciated. thank you.
PS: I am only a programmer, so if theres any problem with wiring that you can suggest, I can only give so much information and understand so much with our electritian not here.
Unread 31-01-2012, 17:47
HoneyBadger4260 HoneyBadger4260 is offline
FRC #4260
HoneyBadger4260 is an unknown quantity at this point
Re: Jaguar is unresponsive
Try flipping the three colored wire around. We moved ours from the table top to the robot and one of them got flipped around. Only took us an hour to figure it out We are rookies so that is all we have for you. Good Luck
Unread 31-01-2012, 18:24
huberje's Avatar
huberje huberje is offline
AKA: Jeffrey
FRC #0151 (Tough Techs)
huberje has a spectacular aura abouthuberje has a spectacular aura abouthuberje has a spectacular aura about
First, you have to make sure the PWM wires (A PWM wire is a red wire, black wire, and white wire held together by an adapter at each end) are connected to the Jaguars!
That's where a PWM wire is supposed to be connected to on each Jaguar. If there isn't one there, there needs to be one connected to each Jaguar and a corresponding port on the Digital Sidecar. If there's one already there, follow HoneyBadger4260's advice.
I hope this helps and good luck!
Unread 31-01-2012, 22:48
TehNovak's Avatar
Skaian Programmer
AKA: Doc Scratch
our PWM cable is orange, red and brown, I believe. unless that's a different cable entirely. but that is whats hooked up from the sidecar to the jaguar. and weve tried honeybadger4360's advice. nothing happened. Do we have the wrong cable or something?
Unread 31-01-2012, 22:51
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Have you started the Driver Station software and enabled the robot? If you have done this, then I would also check to see if your DB37 cable is fixed according to this link. Remember to also put in your team number within the Driver Station so it can correctly assign an IP.
I'm right 90% of the time, so why worry about the other 3%?
Unread 01-02-2012, 10:58
TehNovak's Avatar
Skaian Programmer
AKA: Doc Scratch
we have started the Driver Station and enabled the robot, I believe. And i checked the cable from the cRIO to the Sidecar. It is correct. Any other adivce would be nice, if there is anything left.
Unread 02-02-2012, 11:00
TehNovak's Avatar
Skaian Programmer
AKA: Doc Scratch
I will be posting pictures of what we have so far as far as electrical or hardware and whatnot. so you can better see what is wrong.
[I am an excellent host.]
