Go to Post Well, it's officially that part of the offseason where we all lose our minds again. - Whippet [more]
Unread 02-01-2003, 10:59
Fares Fares is offline
#1009 (Vikings)
Fares is an unknown quantity at this point
Robogui ! sensors don't work
hey guys .we've tried using the sensors , actually we need to use them for our EDU robot , anyhow it looks like the sensors only work under relays .... is that right ? we need it under PWM so we can limit the speed of the motor , any ideas ? using Robogui since we finished everything using that program ...
Unread 02-01-2003, 12:01
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
That's my fault. RoboGUI outputs the following (it's not supposed to be this way):
if NOT (sensorN <<condition>> value) then then label
label
The problem comes from the two "then"s. If you output the code (File->Write Code...) and then delete the second one, it should work just fine.
I just fixed it in the master source and will be releasing the updated version as soon as I finish some other things with it.
Unread 07-01-2003, 16:31
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
That's the same problem I emailed you about today, Rob. Just a few days too late.
Least I've got my own working version already!
Optical sensors with EduBot Gui Cavalcanti Robotics Education and Curriculum 5 02-03-2003 10:05
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
My sensors don't work Fares Programming 2 03-02-2003 18:26
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
