Go to Post Mostly, however, I find that once the students start building a robotics project, they are too busy learning for me to teach. - dtengineering [more]
  #61   Spotlight this post!
Unread 23-01-2012, 19:29
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Re: Running the Kinect on the Robot.
Originally Posted by RufflesRidge View Post
Looks more like Libfreenect, my guess would be hooked up to OpenCV.
At the time I was using the CodeLabratories NUI drivers with OpenCV. I have since switched to OpenKinect (libfreenect). Seems to be working very well. The Kinect is able to track the target and I am working on getting the depth to the target.
  #62   Spotlight this post!
Unread 23-01-2012, 20:03
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
How are you doing the tracking/recognition?
What's your algorithm? It seems to be fairly fast..
My knowledge of CV is rather limited (the basics of edge, corner detection, the high level understanding of stereo vision, scrolling window.. machine learning based pattern matching etc..), and I haven't had much experiences with OpenCV.
A basic flow of your algorithm would be nice if you're willing to share
  #63   Spotlight this post!
Unread 24-01-2012, 01:39
I will post a general outline of my algorithm once I get something more solid down. I have improved it greatly since those videos.
Depth measurements and angle based tracking have been locked in.
  #64   Spotlight this post!
Unread 24-01-2012, 14:48
Another video. Yaaaaaaay....
http://www.youtube.com/watch?v=6M3MpksczlY
  #65   Spotlight this post!
Unread 28-01-2012, 00:13
Any explanations soon?
  #66   Spotlight this post!
Unread 30-01-2012, 16:21
Yeah...maybe this week. I kind of want to get things perfected first.
I got out Pandaboard and will be working on getting things running on that this week.
  #67   Spotlight this post!
Unread 31-01-2012, 11:36
spying189 spying189 is offline
I will get back to you on that.
FRC #2523 (Hilltoppers)
spying189 is an unknown quantity at this point
Originally Posted by realslimschadey View Post
are there any drivers that we need to use the kinect with the driver station. it says i need a server. does the new driver station come with it. when i plug the kinect into the classmate it doesnt recognize it????????
Originally Posted by RoboMaster View Post
realslimschadey, please look at some other threads, resources from FIRST, or start your own question thread. This thread is about using the Kinect on the robot, like a camera.
To use the Kinect on the robot, you would need either a computer ON the robot, or have the Kinect USB somehow streamed wirelessly to the Classmate/FIRST laptop for translation, then sent back to the bot for angle determination. FIRST provides all the resources through their "Technical Resources" webpage.
http://www.usfirst.org/roboticsprograms/frc/2012-kit-of-parts-driver-station/ This webpage provides you with all the links that you will need. First, you need to download the NI Labview Update in order to have the Classmate up to date, along with a update for FIRST utilities, and the Driver Station Update. These MUST be installed **IN LISTED ORDER** to run the supported version of the Driver Station. To give your Classmate/FIRST laptop the ability to support Kinect use, you must first ensure the computer meets the following system requirements.
It must have:
Microsoft Windows 7 Starter Edition and up
2.0 GHZ Processor or higher
1 GB of RAM or higher
3 GB or more of FREE HARD DRIVE space
To get the Kinect running after the Driver Station is installed, download & install the Microsoft Kinect SDK. After doing this, download/install the FRC Kinect Server software. This will allow FIRST software cross-compatibility between the Kinect SDK and the FIRST software.
Finally, download the Kinect Kiosk software to enable viewing of what the Kinect sees on the Driver Station. (Skeleton or not.) If you would like it to act just as a camera on the robot, then you will have to somehow program that into the FRC Dashboard (Editing the Driver Station code isn't allowed).
Hopefully this will help those who needed it working!
  #68   Spotlight this post!
Unread 31-01-2012, 13:27
First of all, you don't need windows for the kinect oon the robot. In fact, it is probably a bad idea, because libfreenect is just better than Microsoft's sdk
  #69   Spotlight this post!
Unread 31-01-2012, 17:25
azula369's Avatar
azula369 azula369 is offline
AKA: Jess
FRC #3555 (Aluminati)
azula369 is an unknown quantity at this point
We're a beginning team considering using a USB wireless extender (http://www.usbfirewire.com/Parts/rr-47-2022.html) to transfer the data collected by the Kinect to the Classmate, process it there, and then transfer it back through the radio. Does this sound feasible, and also legal, to the more experienced teams?
  #70   Spotlight this post!
Unread 31-01-2012, 17:49
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Your first statement is definitely correct.
However I'd be curious as to what makes libfreenect better.
For me I think it would save money and weight, but the library itself isn't necessarily better.
The key function I utilize in the MS SDK that makes the vision processing for this game quite a bit easier is the GetColorPixelCoordinatesFromDepthPixel function. This makes finding the intersection of the RGB and depth images much easier.
As far as I know achieving this in labfreenect takes a good deal of work and calibration. Also, I've found OpenKinect to be a pain to install, and watched it kill my machine the last two times I've tried to install it on windows.
I don't believe one solution is "better" than the other, it all depends on the approach and the application.
  #71   Spotlight this post!
Unread 31-01-2012, 18:40
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Feasible depending on range, but not legal. The only wireless communication allowed is the robot radio.
  #72   Spotlight this post!
Unread 31-01-2012, 19:04
azula369's Avatar
AKA: Jess
OK, but buying and connecting a Pandaboard is legal, right? So that's plan B. Are there any legality issues we should be aware of with that?
  #73   Spotlight this post!
Unread 31-01-2012, 21:18
That sure is a mouthful haha. This is not that difficult with libfreenect, especially with OpenCV (for me, anyways). Besides, not real need for the RGB feed anyway. ;-)
libfreenect is a pain to install on Windows. It's cake on Linux, though.
  #74   Spotlight this post!
Unread 31-01-2012, 21:58
Got the Kinect running on our Pandaboard tonight. It's a little slow, but I have a few ideas on how to speed it up.
  #75   Spotlight this post!
Unread 31-01-2012, 22:16
I'd love to know what framerate you're seeing and what kind of processing you're doing. Are you using both feeds or just opening the depth stream?
