Go to Post Teams that are consistently designing and end up with weight problems need to look at their design process and make corrections in "Weight Management". - Mike Martus [more]
Unread 31-01-2012, 18:09
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
KOP Joystick
WE have the Logitech KOP Joystick from a few years ago and I was wondering how you reference the dial on the bottom. We used it a few years ago, but that programmer left. I tried it as axis 3 but it didn't work.
Unread 31-01-2012, 19:07
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Re: KOP Joystick
from last year I looked into the setup of 2 joysticks (1 being the Attack 3 from the KOP) and this is what I found, but in the post before it, someone mentions the dial is Axis 4, but I am not sure as to where it stands.
But this is what I found
For the Attack 3 Joysticks:
Axis 6 - nothing
axis 5 - nothing
axis 4 - nothing
axis 3 - dial at base of joysstick axis
axis 2 - y axis
axis 1 - x axis
For the Cyborg X Joystick:
Axis 6 - left/right on thumb axis
axis 5 - right throttle axis
axis 4 - rotation axis
axis 3 - left throttle axis
axis 2 - y axis
axis 1 - x axis
I suggest testing Axis 4 if Axis 3 did not work.
Good Luck!
Unread 31-01-2012, 19:14
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Re: KOP Joystick
Axis 6 - nothing
axis 5 - nothing
axis 4 - nothing
axis 2 - y axis
axis 1 - x axis
axis 2 - y axis
axis 1 - x axis
Good Luck!
the dial is on on a +1 to -1 scale, same as the motors, theoretically you could use them to control motors, on the joystick there should be a plus and minus im not sure if its up of down is -1 but i think its up
Unread 31-01-2012, 22:55
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Re: KOP Joystick
m_LeftStick->GetThrottle()
m_Roller->Set(m_LeftCoDriverStick->GetThrottle());
Unread 01-02-2012, 18:53
dmitch's Avatar
Re: KOP Joystick
Alright, thanks. We got it to work with axis 3, we had it outside of the If (IsOperatorControl) statement earlier...(oops)
