Go to Post I am not short, I am just conveniently packaged. - kio_chan176 [more]
Unread 31-01-2012, 20:10
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Loop in autonomous carries on into teleop and stops anything from working?
I have teleop working fine when its enabled first, but (My autonomous code is not working yet but thats a separate issue) after enabling autonomous, neither it nor teleop works at all. Also, we have a do while loop set up in autonomous that doesn't actually stop when turned to teleop. Is this a driver station bug or maybe is it the fact I dont have watchdog enabled? Any suggestions?
   public void autonomousPeriodic(){
        int x = 1;
        do{
            gyro.reset();
            int i=0;
            while(i<4){
                drivetrain.drive(0.5,0.0); //START GOING STRAIGHT
                Timer.delay(4.0);
                drivetrain.drive(0.0,0.0); //STOP
                Timer.delay(4.0);
                gyro.reset();
                double angle = 0;
                do {
                    drivetrain.drive(0.0, 0.15); //TURN
                    Timer.delay(0.5);
                    angle += gyro.getAngle(); //
                    gyro.reset();
                    log("Gyro reads "+angle);
                }while(angle<90); //Keep going in increments of .15 until gyro returns more than 90 degrees
                Timer.delay(4.0);
                i++;
        }while(x>0);
That's our autonomous.
Unread 31-01-2012, 20:26
kgabbott kgabbott is offline
FRC #2035
kgabbott is an unknown quantity at this point
Re: Loop in autonomous carries on into teleop and stops anything from working?
This is occurring because you enter the do while loop and never reset x to a value less that 0, meaning the code continuously runs through this loop.
Unread 31-01-2012, 20:51
AKA: Joel Gallant
Funny, we fixed that, and still have the error with our very simple fix.
This does the same thing.
timer.start();
do{
}while(timer.get()<4);
And yes, we did initialize the timer.
Unread 31-01-2012, 20:54
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
Do this instead:
while (isAutonomous() && isEnabled()) {
    // Autonomous code
Unread 01-02-2012, 11:49
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
do{
}while(timer.get()<4 && isAutonomous());
Unread 01-02-2012, 16:31
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
I would suggest doing it the way Neal has wrote it. You can always have if statement or switch statement handling the time base options.
Unread 02-02-2012, 16:14
AKA: Joel Gallant
Thanks for the replies guys. What I found out was that the iterative robot class is a completely different concept than simplerobot. I was mistaken in thinking it was just more features.
