Go to Post Team 71: So good at Strategy they already have figured out next years game before the GDC has even met. - IKE [more]
Unread 31-01-2012, 19:54
LongNguyen LongNguyen is offline
FRC #3929
LongNguyen is an unknown quantity at this point
Identify this Item Please?
Hello, I don't recall the name of a particular item but I can describe it.
It is T-shaped that contains a hidden spring. By pushing a button on top, it releases the spring.
The width of this object is about 1.5 inches.
Unread 31-01-2012, 20:07
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Re: Identify this Item Please?
Need a little more detail than that. What is it supposed to do?
Unread 31-01-2012, 20:08
FRC #3929
It works like a screw, keeping things in place, however, it takes much less time to remove than a screw does.
Unread 31-01-2012, 20:10
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
quick release pin
Unread 31-01-2012, 20:11
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Is this what you are talking about:
It's a type of quick release pin and it's the only thing that comes to mind with such a vague description.
Jason
Unread 31-01-2012, 20:18
FRC #3929
Yes! That is exactly what I'm looking for! Thank you so much!
Unread 01-02-2012, 09:35
Long,
Incase you were still looking at where to order these, go here http://www.mcmaster.com/#standard-qu...e-pins/=g25d9w
