Go to Post To put it simply, its clearly become this. The teams that can score a lot, do well. Rather shocking, isn't it? It doesn't matter if you're a shooter, dumper, power dumper, gravity dumper, spitter, flinger, dunker, shumper, barfer, dropper, or whatchamacallit. Points are points. - Looking Forward [more]
Unread 31-01-2012, 21:15
Andrew Lawrence
Posts: n/a
Examples of wide-based robots using traction and omni wheels
I need to prove to my mentor that 1 set of omni wheels and 1 set of traction wheels will make really good turning for our wide-based robot. Does anyone have any videos/pictures (vids preferable) of robots that fit this description?
I already searched on CD and Google for a while and found nothing, so I'm hoping some teams know of some.
Thanks!
Unread 31-01-2012, 21:19
ttldomination's Avatar
Sunny
Re: Examples of wide-based robots using traction and omni wheels
http://www.youtube.com/watch?v=Ge8AA...9&feature=plcp
We had a long base 4wd with a set of omnis in the back. Obviously if it worked with long, then it'll turn fine on a wide drive base.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 31-01-2012, 21:22
Andrew Lawrence
Posts: n/a
- Sunny G.
Thanks!
Unread 31-01-2012, 21:24
- Sunny G.
Too well, possibly.
A wide wheel base won't have nearly as much trouble turning as a long base anyway. Just go with 4 tractions/lunacy wheels if you're doing a wide base; adding omnis could result in too much turnability.
Unread 31-01-2012, 21:26
Andrew Lawrence
Posts: n/a
Too well, possibly.
Our problem is we want to extend the wheels out a bit farther, and our wide robot already has a larger wheel base than our long 6 WD.
Unread 31-01-2012, 21:28
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Exxperiment with omnis and tractions in opposite corners.
O---------T
l----------l
l----------l
T---------O
Unread 31-01-2012, 21:30
Andrew Lawrence
Posts: n/a
O---------T
l----------l
l----------l
T---------O
This seems interesting, but I don't see why it's any better than tractions in front and omnis in the back.
Unread 31-01-2012, 21:37
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
The benefit will lie in turning.
Unread 31-01-2012, 21:39
Sunny
One thing that the team felt in 2010 (the video above) was a significant amount of fishtailing. With the wide base, perhaps you'll feel a significant amount of that compounded with increased sensitivity.
With the setup that PayneTrain has suggested, notice that there is no real point about which the robot can fish tail. It forges stability into a potentially unstable design all while distributing the weight over omni wheels and traction wheels.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 31-01-2012, 21:40
Andrew Lawrence
Posts: n/a
Your wording makes we want to test that right now. I think we'll possibly stick to using *gulp* Lunacy wheels. They fit our needs, and we'll be able to keep our bot the way it is without changing too much right now.
Unread 31-01-2012, 21:41
Thanks!
This is probably wrong actually. If you have a wide base robot, and you're powering all wheels, you should have 0 issues with wheel scrub while turning.
Unread 31-01-2012, 21:47
Andrew Lawrence
Posts: n/a
We are currently using the new 6" wheels in the kit, and using the spacing provided. While we turn, we don't maneuver/turn as well as we'd like to. FURTHERMORE, the main reason we're looking into this is because we want to move our wheels out a bit more so we have a bit more stability for the robot, thus making it even harder to turn, especially with the 4" AM plaction wheels we will be using as of tomorrow.
Officially, I can't say it's bad, since we didn't test on carpet. However, we tested on pretty slick concrete that may have been even easier than carpet, and that's what scared me. We will test on real carpet tomorrow.
Unread 31-01-2012, 21:52
Squeakypig's Avatar
Squeakypig Squeakypig is offline
AKA: Mike Coyle
FRC #2851 (Crevolution)
Squeakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond reputeSqueakypig has a reputation beyond repute
1 set of omnis and 1 set of tractions...after seeing other people's comments, I have further understood what you have meant...
But I had to post what I was thinking - I introduce to you, the magic of Nanodrive.
http://www.youtube.com/watch?v=_hTyX...eature=related
Unread 31-01-2012, 21:56
Andrew Lawrence
Posts: n/a
I love that robot. It's one of my favorites on my playlists (Anything 148, really). While I love the drive, it's a little complex for us right now, and especially for this late in the season.
Thanks for the post, though!
Unread 31-01-2012, 22:45
IraJason IraJason is offline
In Search of "Bang Head Here" Sign
AKA: Ira Goldberg
FRC #3632 (D-Tecs); FRC #1712 (Dawgma)
IraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant future
Send a message via AIM to IraJason Send a message via MSN to IraJason
Make sure to report back once you do test on carpet... it really can make the difference in how your drivetrain performs
Many respectable physicists said that they weren't going to stand for this - partly because it was a debasement of science, but mostly because they didn't get invited to those sort of parties."
-Douglas Adams The Hitchhiker's Guide to the Galaxy
2007 Galileo #6 seed, 5th Alliance Captain, Semi-finalist
2007 Philly Regional #4 Seed, Philly Regional GM Industrial Design Award Winner
2006 Philly Regional Highest Rookie Seed,Philly Regional Rookie All Star
