Go to Post While we're on the topic of games... there have to be some people who'd be interested in a good round of FIRST ROBOTICS!!!!!!!!!!!!!!!!!!! :p :yikes: :D :rolleyes: - Leav [more]
Unread 31-01-2012, 21:44
gnichols gnichols is offline
FRC #3862
gnichols is an unknown quantity at this point
Re: Ni Vision Help???
How are you getting the C code out of the Vision program? When I try to create the code it says
This feature is disabled in the evaluation mode, please purchase the product.
It tells me I am using an invalid serial number when I enter the number used to validate the other NI software.
Unread 31-01-2012, 22:11
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
we had a hard time exporting it to labview from the vision assistant as well, it either gave us the eval version error, or just brought labview to the foreground, and didn't actually create any VIs.
However, each 'step' in the Vision assitant you create, matches up with a VI from the vision palletes, so we just made the sequence ourselves, with the values we discovered using the vision assistant.
Unread 01-02-2012, 14:12
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
I'm not well versed in how the licensing works, but you should try calling national instruments (I've heard they are quite helpful); as they should be able to get you a new license key if you have a bad one.
