Go to Post We considered naming our 2014 robot "Please Don't Point it at Me". I think the name fits. - KosmicKhaos [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 31-01-2012, 22:00
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Inventor Drawing for star rod?
I understand what you're looking for, but if you want the correct version, the best option is to measure the real thing and create the file to the length and the exact size that your actual part happens to be. Even a cheap set of calipers will get you within a few thousandths.
You never know if parts will vary from production run to production run. When I teach my CAD classes I always use the example of a piece of printer paper... How often do you think an 8.5X11 sheet of paper is exactly 8.5X11 and perfectly square in the corners?
Measure what you have in front of you. Not only do you get to have the exact representation of what you actually are working with, but you also get the benefit of learning how to create a new object that might make you think a little.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
