Go to Post Inventing rocks. I think we've all learned that through FIRST. - Billfred [more]
Unread 31-01-2012, 18:33
Redstone's Avatar
Redstone Redstone is offline
Me gusta java
AKA: Ben Beals
FRC #4043 (Nerd Herd)
Redstone is an unknown quantity at this point
MaxSonar range
What is the syntax to get a range from our MaxSonar sensor and how do we access the analog inputs?
Unread 31-01-2012, 22:34
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Re: MaxSonar range
I'm currently using AnalogChannel
Can't seem to get it to stay accurate (it is for a while.. then just gives me false readings)
Unread 01-02-2012, 13:03
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: MaxSonar range
AnalogChannel objects provide the way to access the analog input channel. Create one on the specified channel number, and then call the GetVoltage() method or something similar to read the voltage on the channel
Attending: MN Duluth Regional
