Go to Post I can follow directions, but if it's not in the directions, I'm lost. - rclothier [more]
Unread 01-02-2012, 01:58
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: TTL serial into the cRIO RS-232 Port?
Thanks. I've already ordered the slightly updated version of that board http://www.sparkfun.com/products/8780 just in case. I'm just hoping someone has tried just running TTL level serial into a cRIO and will tell me it works fine without it.
We're getting weird data with our first pass code in Java so we don't know if that's the code or an interface problem.
Unread 01-02-2012, 06:40
Chris_Elston's Avatar
Chris_Elston Chris_Elston is online now
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We have used the TTL board from the 2005, 2006 CMU Camera just fine into the RS-232 for testing to convert a microprocessor TTL into RS-232 into the CRIO-I serial port. If you have one of those laying around to try it, it works.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 01-02-2012, 06:54
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
It will not just work - you need a converter. Several have been mentioned in this thread. Here is another choice http://www.blackbox.com/Store/Result...s/n-4294966762
HTH
Unread 01-02-2012, 11:47
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Good idea on the old TTL board from the CMU Cam. That would be good for testing at least (I don't know that's it's an off the shelf item.) I'll see if I can find that again.
Unread 01-02-2012, 13:50
If you didn't modify it previously, it would be legal per [R24]. The IFI site confilicts itself (It says it's In Stock and Discontinued right next to each other). http://ifirobotics.com/camera.shtml
