Go to Post I think I wanna buy a Segway just to throw myself in the air to see what would happen... - Elgin Clock [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 18-01-2012, 10:51
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
2CAN firmware update
Version 2.21 firmware is now available and compatible with all verisons of the 2CAN.
Fixed a bug in jaguar flash utility that failed to flash on first attempt, Forcing the Jag into bootloader.
http://www.crosstheroadelectronics.c...2_21_FIRST.crf
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 27-01-2012, 14:44
gwlund gwlund is offline
FRC #2605
gwlund is an unknown quantity at this point
Re: 2CAN firmware update
Mike,
Thanks for the support of FRC. Looking to get a 2CAN unit to help our battles of troubleshooting crappy serial cables and computers with no serial ports. I saw that both you and AndyMark are out of units. Any word on when you'll have more in stock?
Gil
Team #2605
Unread 01-02-2012, 02:23
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Which firmware should we be using at this point? We had ver. 2.5 running on the 1st gen board, and it seemed to work. That was until we tried updating the firmware - sent it into the bootloader. After that, I reflashed it with the 2.21 firmware, hooked it up to a second Jag, and that one also went to bootloader saying it had a timeout. Eventually, I just gave up and flashed them with BDC-Comm.
Trying to load the code, on the reboot, it seemed to hang again as the system was up, but the code would not load until a physical hard reset was done. I remember seeing this issue last year, but thought it was taken care of with an .out file update.. Is there any update to that too? I can verify if that is what is happening tomorrow for sure (I didn't have a serial cable hooked up to see where it was hanging)
I'm right 90% of the time, so why worry about the other 3%?
Unread 01-02-2012, 21:39
Cecil's Avatar
AKA: Alex Hummel
I hooked up the hyperterminal today, and I did verify that the plugin was hanging on shutdown. It wasn't a permanent hang, although it took a good 3 minutes for the system to actually shut down and proceed with the reboot. The output looks like:
[SYSTEM MESSAGE] System is Shutting Down...
Unloading startup library FRC_2CANPlugIn
FRC_2CANPlugIn_StartupLibraryCleanup() - SVN revision 72
I'm sorry if I sound like I am complaining, it really is just a minor inconvenience, but at the same time, if code has to change right before we go onto the field... D:
Unread 16-02-2012, 19:50
The latest version of 2CAN firmware can be found at:
http://www.crosstheroadelectronics.c...2_24_FIRST.zip
Version 2.24 fixes a bug in the SPI hardware test that occasionally causes the hardware test to fail resulting in a red/orange LED.
Also a bug in the Jaguar firmware update tool that would cause the firmware upload to fail on some machines has been fixed.
Mike Copioli
