Go to Post My first reaction was "Where am I am gonna find pool noodles AND inner tubes in the middle of winter in Michigan?" - KTorak [more]
Unread 31-01-2012, 16:54
davidrk13 davidrk13 is offline
FRC #2554
davidrk13 is an unknown quantity at this point
cRio sensitivity?
How sensitive is the cRio? Currently, I'm planning to mount it on the wall (the back of the robot), but I've been having second thoughts. Will the cRio being mounted at the back with the robot while colliding with other robots affect how it functions. I'm doing this to conserve space btw
Unread 31-01-2012, 16:56
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: cRio sensitivity?
The cRio is built pretty robustly. We mounted it more or less against the back frame for Breakaway, and never had a problem with it, despite getting banged up by other robots and going over the bump.
Unread 31-01-2012, 23:16
I wouldn't worry too much about it. After watching this, you probably won't worry too much either.
Unread 01-02-2012, 07:56
Gdeaver Gdeaver is offline
FRC #1640
the modules can pop out. Secure them.
Unread 01-02-2012, 10:41
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Modules might pop out above 50G of force (closer to 100G actually), so yes, this should be taken into account. However, the bigger problem is loose wiring. Also, not all of the components are rated for shock, so take care mounting your radio and camera.
