Go to Post So, we should have respect for each other regardless of whether we are building our robot with a Waterjet or a Hacksaw. Construction methods will vary widely, but honoring your competitors should be universal. - OZ_341 [more]
Unread 01-02-2012, 09:40
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Re: New version of the WPILib Cookbook posted
Thanks for this cookbook... it has helped us tremendously.
One question... in the example Command described, you get various subsystems using [Subsystem].getInstance(). In the Subsystem class there is not a static instance member, rather it is in the CommandBase. Do you recommend putting the static instance in the CommandBase or putting it in the Subsystem and writing a GetInstance() method on the Subsystem? Sample below.
public class DriveWithJoystick extends CommandBase {
Chassis m_chassis;
public DriveWithJoystick() {
m_chassis = Chassis.getInstance(); // not available...
requires(m_chassis); // reserve the chassis subsystem
