Go to Post "Pimp my shopping cart"?!?! - dlavery [more]
Unread 01-02-2012, 10:16
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
pic: Wave Robotics 2826 Drive Teaser
Unread 01-02-2012, 10:17
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
Re: pic: Wave Robotics 2826 Drive Teaser
With that low of a ground clearance I take it you're not going over the barrier this year?
2012-2016 Wave Robotics Team 2826
Unread 01-02-2012, 10:18
I think they are. That's a Delrin angle on the near end, or I'm greatly mistaken.
Unread 01-02-2012, 10:22
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
The sheetmetal parts are looking great this year guys. Looking forward to seeing the completed robot. I'm interested to see exactly how you are powering the wheels as it appears to be dead axles (3/8" Grade 8 Bolts) but I don't see any pulleys or sprockets.
Looks like about an 1" of ground clearance. And I believe those slides on the front edge of the chassis (im guessing teflon, Delrin, or HDPE) allow them to go over the barrier, FRC2168 is doing something similar this year.
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
What size are the wheels? I don't really have a good perspective to tell if they are 4" or 6".
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 01-02-2012, 10:23
Andrew Lawrence
Posts: n/a
Excuse my curiosity, but what's a Delrin Angle? I'm assuming it's the slanted piece to go over the bump, but then again, you never know. Well, you probably know, but I don't.
Thanks!
Unread 01-02-2012, 10:25
Thanks!
The angled part of the frame appears to be covered by Delrin, which is a rather slick type of plastic. The other option that I can think of, HDPE, is also somewhat slick, but Delrin is slicker. In block form, Delrin has been used as a chain tensioner in the past--stick the block in so the chain is slightly too tight and let it find its own tension by digging into the block.
Unread 01-02-2012, 10:28
Andrew Lawrence
Posts: n/a
Thanks! I appreciate it!
Thanks!
Delrin is a material developed by DuPont and is widely used by teams. That piece could also be HDPE or UHMW.
Unread 01-02-2012, 10:34
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
If you zoom into the picture, it looks as if the wheels are riding on hex shafts, if so, I'd imagine that the ends of the shafts have been drilled and tapped to allow the use of bolts as retainers.
-Dustin Benedict
Unread 01-02-2012, 14:00
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
That sheet metal work is absolutely gorgeous. Looking great so far! How high will your bumpers be?
Unread 01-02-2012, 14:07
FYI
Delrin is the Dupont trade name for Acetal.
Thank-you 294 & 67
Unread 01-02-2012, 14:45
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
That robot is definitely going over the bump.
Unread 01-02-2012, 15:56
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
I only have one question what is the angle of the thing in the front?
Unread 01-02-2012, 18:16
mr.roboto2826's Avatar
mr.roboto2826 mr.roboto2826 is offline
AKA: Niklas Olsen
FRC #0148 (Robowranglers)
mr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nice
We are powering the wheels Via belt and pulley, similar to a west coast in some respects. It runs inside of the 2 C channels that make up one side of our drivetrain. The wheels are our custom 4".
