Go to Post [E]specially when Murphy is around (or at a robotics competition), reality tends to win over physics. - EricH [more]
Unread 28-01-2012, 19:42
bradywilmer bradywilmer is offline
FRC #2883
bradywilmer is an unknown quantity at this point
Compressor Programming
We are having an issue getting our compressor to work with the pressure switch to our digital side car. We have an 8 slot cRIO with the 9403 in slot 2 connected to our digital side car by the DB37 cable. Our robot drives and relays operate so we are relatively sure the digital side car is functional. Our pressure switch is wired to SIG and negative on digital IO 1 on the digital side car. We've placed the compressor control loop in the Periodic Tasks.vi and in the begin .vi. We really could use an example of a successful compressor program. Thanks.
Team 2883
Unread 28-01-2012, 23:31
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
Re: Compressor Programming
There should be an example showing both correct code and correct wiring. Look in the FRC examples.
Unread 29-01-2012, 01:49
FRC #2883
There has to be an easier way to do that. I made a successful compressor program with the last version of labview, but I haven't been able to do that with labview 2011.
Unread 29-01-2012, 04:24
NeatNit's Avatar
Alumni Programmer
Compressor's a little bit different to program this year. Well actually, the only noticeable difference is that you must include the Control Loop in periodic tasks. This VI must be outside of a loop, it has loops inside it.
Unread 01-02-2012, 10:54
FRC #2883
Im pretty sure I have the programming right. Can someone explain how I should have it wired? Right now I have Digital Module 1(slot 2 of our 8 slot cRIO) connected to the digital side car. Relay 1 on the side car is connected to the spike relay. The spike relay is connected to the compressor and the power distribution board. DIO 1 on the side car is connected to the pressure switch which is connected to the compressor. Please let me know if any of this is wrong
Unread 01-02-2012, 12:11
Your wiring sounds correct.
Do the Relay LEDs on the Digital Sidecar (right in front of the Relay pins) come on at all?
You can test the DIO 1 input by substituting a regular switch on the sig/gnd pins. or just jumping the sig to gnd.
The Relay LEDs will be off or green depending on how the switch is thrown if the code is operating properly.
You can debug from there.
