Go to Post The engineers and mentors provide the "I" in FIRST and FIRST would be nowhere near where it is today without this exceptional leadership shown by so many of these volunteers. - Chris Fultz [more]
Unread 01-02-2012, 13:42
brunoUC's Avatar
brunoUC brunoUC is offline
AKA: Bruno Toso
FRC #1156 (Under Control)
brunoUC is an unknown quantity at this point
ni vision assistant help!
hi, this is my first time programming the camera and i'm having some trouble using the ni vision assistant.
I'm trying to locate the rectangle in the basket by converting the image to grayscale and then to binary but i wasn't able to make the program locate the rectangle. i've already read the white paper and other tutorials but i couldn't find anything that helped me.
thanks from team #1156
Unread 01-02-2012, 13:58
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Re: ni vision assistant help!
If you use the example vision code, everything is taken care of, and is much more accurate than any code that our team has ever drafted up...
Unread 06-02-2012, 10:30
brunoUC's Avatar
AKA: Bruno Toso
thank you, the example is realy useful i've already adapted it to our robot code and it's working as it should. But i've been trying to use the distance and coordinates that it gives me and i couldnt find a way to separate the informations from the array.
also, is there any way to use select the color i want without opening the code and using the pointing tool?
Unread 06-02-2012, 12:37
Originally Posted by brunoUC View Post
...i couldnt find a way to separate the informations from the array.
Use the Index Array function from the Array function palette. You can choose which of the elements of the array to pull out as a single cluster of values. Then to get the individual values from the cluster you use a function from the Cluster, Class, & Variant palette: Unbundle by Name.
Unread 13-02-2012, 16:06
brunoUC's Avatar
AKA: Bruno Toso
thank you!
i managed to aquire the coordinates and distances, but i still couldn't make the program find the color of the tapes without selecting it, is there a way to place it on the dashboard or something like that?
Unread 14-02-2012, 01:23
Run the code so you can see the vi's front panel. Select the color you want to seek. Then you can stop the code and use the right-click menu on each of the six numeric color range values and choose Data Operations>Make Current Value Default (I'm typing this from memory and might not have gotten the names quite right). That makes the change stick for the next time you run or build the code.
