Re: Autonomous with Ultrasonic sensor doesnt work!!
[/quote]
Thanks in advance. Last edited by cilginbilgin : 01-02-2012 at 14:48. |
Please see the post from MotorHead above. You autonomous code should look similar to his when your finished. |
http://www.mypicx.com/02012012/Autonomous/ and I think my autonomous code is pretty same with MotorHead's. |
Your logic seems correct. However, you may not be getting anything from the ultrasonic sensor. See the attached image of the ultrasound example (the example can be found in (LabviewInstallFolder)/examples\FRC\Analog\EZ1 MB1010 Sonar Analog).
The example sets the averaging, sets sample rate, and then gets the voltage within the while loop. We tried moving the "set averaging" and "set sample rate" to Begin.vi, but the "analog get voltage" stopped working when we did that. Perhaps you need to add the "set averaging" and "set sample rate" into your while loop. Can you describe the following: 1) How exactly is your robot behaving when you run autonomous? 2) When you run autonomous, what are you seeing from your "Distance" indicator? |
I haven't used the Ultrasonic yet, so I can't comment on its setup. I do have a problem with your logic. The way you currently are configured is: If distance >= to 40 then back up with y =-.4, If distance < 40, stop and activate solenoid.
The problem with this is you do not have a deadzone in which to stop. Your arrangement can cause the robot to excessively hunt about the setpoint of 40. Look again at the vi I posted. There is a nested case structure to test if you are above or below the setpoint or if you are within the acceptable deadzone, in which case, do nothing. |
Thank you guys for your helps!!!!! ![]() |
#7
Or you could control the motor speed based on how far away you are, slowing down as you approach the target distance so you don't overshoot. For example, set the motor output to a value proportional to the error between the desired location and the measured location. If your proportionality constant is too high, you will overshoot (and then perhaps back up to the target, depending on the details of the code). If the constant is too low, you will stop too soon, so you can use another term that increases motor speed based on how long the position error is present. You can also reduce power if you're approaching the target too quickly. Put it all together and you have PID control -- search the forums for more discussion and explanation. |
