Go to Post You know it’s a tough game when you see a bearing on the floor. - D.Allred [more]
Unread 01-02-2012, 14:42
Gil3075 Gil3075 is offline
FRC #3075 (Ha-Dream Team)
Gil3075 is a glorious beacon of lightGil3075 is a glorious beacon of lightGil3075 is a glorious beacon of lightGil3075 is a glorious beacon of lightGil3075 is a glorious beacon of light
2012 Ranking Question
hi there,
I am doing some research for my team's scouting plan and I found this:
http://www2.usfirst.org/2012comp/eve.../rankings.html
I guess that QS stands for Qualification Score, and it seems like this will be the main parameter to rank the teams, and HP will decide in case of a tie.
However, I have no idea what HP, TP, BP and CP stands for.
any help and more information will be much appreciated
thanks!
Unread 01-02-2012, 14:44
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: 2012 Ranking Question
hybrid, bonus, and teleop respectively
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
hybrid points; balancing points; teleop points...
Unread 01-02-2012, 14:47
I understand now, thanks!
Unread 01-02-2012, 14:53
And you're all missing CP: coopertition points.
The W-L-T is not what it used to be.
QS=2 for a win, 1 for a tie, 0 for a loss. Standard operating procedure.
You also get 1 or 2 QS in the form of CP: 1 for attempting to balance the coopertition bridge, 2 for succeeding. So for any given match, you could get 0 (loss, no coopertition) to 4 (win, balanced coopertition) QS.
Now, from 5.3.6:
The FMS will rank all teams in decreasing order, using the following sorting criteria:
1st order sort Qualification Score
2nd order sort Cumulative sum of Hybrid Hoop points
3rd order sort Cumulative sum of Bridge points
4th order sort Cumulative sum of Teleop Hoop points
5th order sort Random sorting by the FMS
So, QS=(W-L-T)+CS, sort high to low. Ties are broken by HP. If there's still a tie, BP is applied. If there's still a tie, TP is applied. After that, sort any remaining ties randomly.
