Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 01-02-2012, 14:52
Team 3705's Avatar
Team 3705 Team 3705 is offline
FRC #3705
Team 3705 is an unknown quantity at this point
C++ coding vs. Digital sidecar
Why are the ports on the C++ program coding not functioning the ones on the digital sidecar? Especially with Jaguars.
We have 6 jaguars.
When we try to use port 1 and 2, jaguars 3 and 4 are flashing. Port 1 and 2 are hooked up to our CIM motors but they work when we command to use Port 3 and 4 in the C++ coding.
Unread 01-02-2012, 15:21
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: C++ coding vs. Digital sidecar
A lot of teams have reported this. Have you fixed your DB37 cable according to these instructions?
I'm right 90% of the time, so why worry about the other 3%?
Unread 01-02-2012, 16:10
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
We seem to have the same problem but it is associated with a RobotDrive error with the motor safety.
We see this when we loaded last years code. It does not happen with this year's simple template example.
Anyone else seen this error?
Andy Brockway
Team 716, The Who'sCTEKS
Unread 01-02-2012, 16:24
Team 3705's Avatar
FRC #3705
Thanks! We made it work! Our status was light works now also...
than kyou very much XD
Unread 01-02-2012, 21:28
Cecil's Avatar
AKA: Alex Hummel
Remember, with this year's code, the slots are in different places. Make sure you go back through the code and reassign the appropriate slots to make it work.
