Go to Post I'm totally hooked on reffing now and will be volunteering in the future because of [Beach Blitz]. - Ali Ahmed [more]
Unread 01-02-2012, 15:53
Gatekeeper Gatekeeper is offline
FRC #4054
Gatekeeper is an unknown quantity at this point
What electronics need fans?
Inside the Kit of Parts we received multiple cooling fans. What our team is wondering is what electronics or motors need these cooling fans? Do the CIM motors need a cooling fan? Or does the electronics board need a cooling fan directed on it? Or possibly the cRIO?
Thanks in advance! =)
Unread 01-02-2012, 15:56
Re: What electronics need fans?
What KOP electronics need the fans? Probably none. (Jaguars have their own built-in; same for Victors.)
The fans are in case you discover that you need cooling somewhere and decide to run air over that area.
Unread 01-02-2012, 16:00
jon-s's Avatar
jon-s jon-s is offline
Lead Designer
FRC #3335
jon-s is an unknown quantity at this point
I think the most likely application for fans is if the motors are overworked.
Jon. S
Unread 01-02-2012, 16:05
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
If you're using the small 500-series motors, you could possibly use them to aid in cooling them and extend their useful life.
Attending: MN Duluth Regional
