Go to Post ROBUST, ROBUST and ROBUST if you want to win - dan 322 [more]
Unread 01-02-2012, 16:03
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
Problem with the connecting to the host
i get this message every time that i try to debug on eclipse (java)
BUILD FAILED
C:\eclipse\plugins\edu.wpi.first.javadev.sunspotfr csdk_1.0.7.0\sunspotfrcsdk\build.xml:96: The following error occurred while executing this line:
C:\eclipse\plugins\edu.wpi.first.javadev.sunspotfr csdk_1.0.7.0\sunspotfrcsdk\ant\upgrade.xml:40: java.net.NoRouteToHostException: No route to host: connect
not yet defined for cRIO IP address, so I want to know where to update the address.
Unread 02-02-2012, 16:32
anipirakis anipirakis is offline
AKA: Alexandros Nipirakis
FRC #1557 (12 Volt Bolt)
anipirakis will become famous soon enough
Re: Problem with the connecting to the host
I don't know if you already resolved this or not, but your robot's IP address is set by the flashing tool.
I have found that many of the problems with code loading are due to mysterious networking issues. The driver station its self has the tendency to change around networking in many nasty ways.
Regards,
Aleksei
Unread 05-02-2012, 00:45
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
the other problem may be that you have not set your team number in your IDE. i am not familiar with eclipse, but somewhere under options is the FRC options where you set your team's number. that will change the IP you are trying to 10.xx.yy.2
i hope one of these posts helped resolve your problem ^_^ Good luck ^_^
"you can build a perfect machine out of imperfect parts" -Urza
Unread 05-02-2012, 01:54
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
How to set your team number in each IDE:
From within eclipse:
Windows > Preferences
From within Netbeans:
Tools > Options > Miscellaneous > FRC Configuration
http://team2168.org
