C++ coding vs. Digital sidecar
Why are the ports on the C++ program coding not functioning the ones on the digital sidecar? Especially with Jaguars.
We have 6 jaguars. When we try to use port 1 and 2, jaguars 3 and 4 are flashing. Port 1 and 2 are hooked up to our CIM motors but they work when we command to use Port 3 and 4 in the C++ coding. Last edited by Team 3705 : 01-02-2012 at 14:57. |
Re: C++ coding vs. Digital sidecar
A lot of teams have reported this. Have you fixed your DB37 cable according to these instructions?
We seem to have the same problem but it is associated with a RobotDrive error with the motor safety.
We see this when we loaded last years code. It does not happen with this year's simple template example. Anyone else seen this error? |
Thanks! We made it work! Our status was light works now also...
than kyou very much XD |
Remember, with this year's code, the slots are in different places. Make sure you go back through the code and reassign the appropriate slots to make it work.
