Go to Post I think this post is a lot of words saying "My name is Billfred and I approve MiniBots 2017" - Andrew Schreiber [more]
Unread 01-02-2012, 16:33
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Re: Difference between Shift Register and Feedback Node
Originally Posted by Omar View Post
We use shift reg all the time in teleop.
The number one way I use shift reg is in single loop while loop just to store a value for later use.
Could you explain more about this? Post a code example perhaps. I was under the impression as well that you could not do this since the shift register involved a loop and you didn't want the loop tying up telop. In the past, I have written information to a Global Variable and let a loop inside of Periodic Task access the value.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 01-02-2012, 16:50
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Our team uses while loops with shift registers to run all of our inputs and outputs. Inside each loop is a case structure with an enum for 3 modes, which are init, run and end. All the code that would normally be placed in the begin VI is placed in the init case, and then that case is run in begin. In run is all of our code that is used at runtime. In end it the code that is normally located in finish. This shift registers are used to transfer the references between the 3 states. This means that we do not need to use refnums which saves some resources.
Team 4488 - Mentor 2013-2016
Unread 02-02-2012, 00:25
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Just be careful with Enums like this. This is very common practice BTW, and one method to keep your code isolated. Your action Enum, (Init|work|end) should always be a TypeDefd control. This also presents the possibility of the constant value automatically changing if the typedef is updated. I typically will write the desired value as a BD note, next to the Enum constant.
Mike B
Unread 01-02-2012, 17:48
The trick is that the stop of the while loop is wired to a true constant, so that the loop only runs once.
