Go to Post "there are two types of underprivileged teams; the ones who whine about being underprivileged and the ones that work to become privileged". - Undertones [more]
Unread 01-02-2012, 18:07
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: 179 Swamp Teasers
Originally Posted by dodar View Post
How does this react with the ball-stopper that is connected to the edges of the birdge? I believe there is a piece of lexan or polycarbonate beneath the bridge on both ends that connects back to the bottom of the bump. Yes, on the wooden practice bridge built to practice field specs only touches on top but if you p[ut that ball-stopper underneath it looks to be able to touch that piece and would therefore be "grasping" the bridge.
That might be a huge issue! When the bridge is balanced, those lexan slants are designed to be at an angle so balls can roll out. It hard to tell based on these pictures but they may be touching those when they are balancing!
Great design, I hope it works out for you in the end!
1058 PVC Pirates 2016 - xxxx
