Go to Post Bumper quality is an "attention to detail" measure. Teams that get little things right tend to do better on the big things. - vhcook [more]
Unread 31-01-2012, 15:54
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
labview update problem
For some reason, when i try to update labview on my laptop to the frc 2012, everything works fine (all of the vi.lib is there) but the startup screen is the 2011 labview regular, and not frc. Does anyone know how to fix this?
Unread 31-01-2012, 22:29
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Re: labview update problem
We had a similar problem. This worked:
http://forums.usfirst.org/showthread.php?t=18673
Unread 31-01-2012, 22:32
After installing LabVIEW from the USB "card" flash drive, did you then install the required update that was specified in the Getting Started document?
Unread 01-02-2012, 18:34
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
yes, all 3 of them in order (many times might i add)
Unread 01-02-2012, 19:44
Bratmon Bratmon is offline
Software Wizard
AKA: Ronnie Weber
FRC #1038 (Thunderhawks)
Bratmon is an unknown quantity at this point
My team had the same problem. Try installing the update here:
http://joule.ni.com/nidu/cds/view/p/id/2261/lang/en
Hope that helps.
