Go to Post Enjoy doing what you do. If you enjoy your life, what you're doing in it, and how you're living it, then what other people say or think doesn't matter. - Beth Sweet [more]
Unread 31-01-2012, 09:14
dm224a dm224a is offline
FRC #4143
dm224a is an unknown quantity at this point
Shooter question
We have a rookie team and are having some debate over how to design the shooter. we are trying to figure out whether it is better to have two of the 8in wheels (from the 2011 KOP) and sheet metal on the top, or to have the same set up with a static or powered wheel at the top. any thoughts? I am wanting to have just the wheels on the bottom for simplicity sake, but does that reduce the range enough to want to add wheels on top?
Unread 31-01-2012, 09:30
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Re: Shooter question
Team 1208 has found the set up in the attached photo to be a very effective shooter. One powered wheel with a fixed polycarb plate as a deflector.
Unread 31-01-2012, 09:32
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
There is some very good discussion in this threads:
http://www.chiefdelphi.com/forums/sh...d.php?t=100293
http://www.chiefdelphi.com/forums/sh...d.php?t=100182
http://www.chiefdelphi.com/forums/sh...d.php?t=101055
If you use the search function at the top, you'll probably find more.
-Dustin Benedict
Unread 31-01-2012, 11:46
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
I noticed that your using a Quikrete tube on your lift mechanism. That is a really neat idea. What is the diameter on it and is there much slop around the ball because of it?
Unread 31-01-2012, 12:00
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
The diameter is labled "8 inches nominal". The ball will fall through the tube, but there is very little gap between the ball and the tube.
Unread 01-02-2012, 19:10
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
Were using two wheels attached together. A motor spins them and launches from the bottom, which gives more power and distance from the top in our tests.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 01-02-2012, 19:13
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
http://www.screamingchickens.org/videos.html
We are a rookie team too and this was our first prototype and it worked great for us. You might find if it was over kill once u see it but work well.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 01-02-2012, 20:19
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Well a powered wheel at the top would constitute a two wheel shooter which, in general, you WILL see much greater distance with. But, as you said, it is more complicated. The way I see it is that you should go one wheel and a sheet hood because we actually don't really need the large distances mentioned before! Aiming from more than half court would be quite the challenge, so do you really need a shooter that can go farther than that?
To note on the static wheel, do you mean free-spinning or fixed, e.g. non-spinning wheel? Having a static fixed wheel seems kind-of wasteful space and weight wise, also I'm not sure it would really even work! Just doesn't seem right...
For free-spinning, that's also a no go. I think you would get in a situation where the ball contacted the powered wheel, began to spin, and just twirled there spinning you're free spinning wheel with it!
+ on that one wheel with a hood, you also get some of that great, magical backspin
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 11-02-2012, 15:00
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
Using 2 wheels and one lexan sheet as a compression point would be good, 2 wheels help give it stability and will be more consistent.
