Go to Post Yes, it is fun. Its fun to watch the students expand their thinking and look outside the "normal" and watch their thoughts explode! Its also fun to watch the mentor's minds fry trying to out think the students.;) - Robert Cawthon [more]
Unread 04-02-2011, 21:17
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
Ultrasonic
Have any teams had success with the Devantech SRF08 sonar + example code? I'm curious if it's worth the investment: in previous years we've had trouble getting an accurate reading with the SRF04's and 05's beyond 1m, while they say they can go up to 3-4m.
Thanks!
Unread 04-02-2011, 21:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Ultrasonic
Well not exactly a Devantech SRF08, but we've had Matbotix Ultrasonic Sensors.
Here's a demonstration video of them.
I blame the programmer though.
Too bad the programmer was me.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 04-02-2011, 23:03
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Ultrasonic
We are planning to use Maxbotix XL-EZ4 this year on our robot and so far have had great success with them. They are extremely easy to wire up (strait into an analog input) and we get cm accurate readings from them. No need for a ping channel unless you are planning on Daisy Chaining them and that's just so they don't interfere with each other. There is only one ping channel no matter how many sensors you want to wire together, much easier than the SRF08s.
http://www.maxbotix.com/MB1240__XL-MaxSonar-EZ4.html
Unread 05-02-2011, 09:13
FRC #0353 (Pobots)
Re: Ultrasonic
Awesome, thanks for the recommendation. And do they work with the basic WPI Library Functions / default code or is custom programming required? Do you recommend analog (13XX) or pulse width (12XX)?
Unread 05-02-2011, 11:44
Engineering Coach
Re: Ultrasonic
We did have to write our own code but it's really easy because its's just reading in an analog value.
You can find the code we are using here
http://code.google.com/p/discobots/s...rc%2F Sensors
I don't guarantee that's its perfect but it should work. (It's in Java)
Unread 01-02-2012, 18:32
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
Discobots: that's a great sample. Thanks for sharing!
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
Unread 01-02-2012, 19:18
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Ultrasonic
Since you're probably just going to be reading the analog output voltage, there's no difference in either model to you.
Attending: MN Duluth Regional
