Drive train questions
We are looking at doing a 6WD system this year and had initially looked at having 2cims direct drive the center wheels and then use belts or chains to power the outer wheels.The design has evolved into using a single cim on each center wheel that is chained to the front and using another cim to direct drive each rear wheel. Does anyone see any issues with the evolved setup.I am concerned about matching speeds between wheel sets and a potential loss of power, but I may be worrying for nothing. Thanks for your thoughts.
Brian Holmgren Team 1723 |
Re: Drive train questions
If you had different motors then you would have needed to (closely) match motor speeds using different gear ratios but since both sets of motors are the same, all you need to do is have the same gearboxes and you'll be fine. |
The matching of speeds may or may not be an issue depending on the type of wheels used. The added weight of extra gear boxes would be a bigger concern for me.
Just make sure that the center wheel is 1/8in lower than the outside wheels or else you drivebase will not turn unless you are using omni or slick wheels on the outside wheels. |
There would still be an advantage to chaining the rear wheels with the center wheels in that in the case where the rear wheels are elevated, the front and center wheels would still be powered by 2 motors instead of just 1, allowing for double the power in this case.
This could also be the case if the normal force is unevenly distributed among the wheels, e.g. center of gravity is more toward the front of the robot or the center wheels are dropped. This would mean the rear wheels would have less load on them because there is a lower frictional force on them, so you would get more out of your motors by chaining the wheels together. Worth noting that these two reasons are both conditional, however. |
#7
If you are in the market for gearboxes, using the CIMple box from the KOP isn't a half bad idea. The ~5:1 ratio is good for the CIM. I am personally a fan of the AM ToughBox which is 12.75:1 if you don't play with the gearing. |
#8
The CIMple gearbox in the KoP has been much better for us. |
#9
6WD must be the thing this year We are doing this as well. What problem are you trying to solve by moving the cim motor off of the center?
I think you are better combining the motors as you then always have the cumulative effect of the 2 motors and the KOP box is prebuilt for it so it isn't difficult. |
#11
I'm not sure why we moved the one motor, but it looks like we're moving it back to a single CIMple box in the center. Yes, definitely using a transmission with a hex shaft to drive the center and then chain up the outside wheels. Thanks for the inputs!
